View Poll Results: Your lifelong fuel economy figures on your MT fits
<23 MPG
1.20%
24-26 MPG
1.20%
27-29 MPG
5.64%
30-32 MPG
16.58%
33-35 MPG
32.99%
36-38 MPG
25.47%
39-41 MPG
10.43%
41-43 MPG
3.93%
>43 MPG
2.56%
Voters: 585. You may not vote on this poll
MT Fuel Economy Poll
Old Dec 25, 2017 | 06:38 PM
  #101
Toronto Fit's Avatar
I get combined low 30s in MPG
Drive in Toronto traffic majority of the time
Old Dec 25, 2017 | 11:12 PM
  #102
radioarno's Avatar
Originally Posted by Fit Charlie
samcl9- Since I blocked the lower grille I've been reliably getting over 50.
Fit Charlie, can you tell how you block the grill, and maybe show a pic? Thanks.
Old Dec 26, 2017 | 05:15 PM
  #103
It was -14 C here in Toronto today and my MPG dipped below 30 for the first time :/
Old Jan 23, 2018 | 10:03 PM
  #104
dll932's Avatar
Originally Posted by RichXKU
Of course... Warm weather always improves fuel economy. Cold temps destroy it.
I get that but the difference is dramatic compared to other cars I've owned with similar curb weight and engine size (all M/T). I drive about 90% freeway, have since new (it's a 2010 Sport). It's rarely driven on weekends and I use cruise 99% of the time. On roads other than freeways, I get to top gear fairly quick but I"m not flooring it. In summer I get as much as 36 but usually 34. In winter it drops to about 30-32. It gets cold in Northern Ohio but rarely single digits.
Old Apr 30, 2018 | 05:52 PM
  #105
evilchargerfan's Avatar
so how do i get into that 43+ catergory ...
Old Jun 19, 2018 | 01:09 PM
  #106
I found out how ....
Old Jul 2, 2018 | 01:37 PM
  #107
san diego to vegas - 333+ miles
about 42 mpg
vegas back to san diego - 333+ miles
about 41 mpg
Old Jul 2, 2018 | 02:15 PM
  #108
nice setup u got dere evil!
Old Jul 5, 2018 | 06:45 PM
  #109
thanks, I was testing out the diff between scangauge vs ultragauge. I ended up liking the scangauge more (personal pref)
Old Jun 18, 2019 | 11:12 AM
  #110
after a little over 1 yr of ownership, and over 30k miles tracked, I am coming in at 40.2 mpg avg
Old Jun 18, 2019 | 02:36 PM
  #111
User1's Avatar
Dang it! You got to my goal! What is your speed usually on the freeway? Granted I'm doing ~80mph most of the time (33mpg). I'd be down in ~65mph if I was getting 40mpg. Oh yeah my tires are at 36psi too. That's the max.
Old Jun 18, 2019 | 02:49 PM
  #112
I use my ScanGauge2 religiously and I try to keep it at/around 20 tps. Doing so will typically show the driver getting 40 mpg real time.
the throttle position matters. mph is almost never a good indicator.
but, to answer your question, on the flat.... I typically find myself going 65 mph. down hills, I can do 80+ if the conditions are right. if I am lucky enough to find a big truck/suv to draft behind, I can easily go faster and maintain same mpg (target is 40) or take the chance to raise my avg #s for as long as I can draft behind the bigger truck/suv.
TIP:
when I go down a hill and see a uphill coming ... I try to get as much speed as possible, like say .... 80+ mph .... so when I do the hill climb, I have momentum on my side and I can slowly decrease my speed via the cruise control + and - buttons, and try to find that balance between a decent climb speed and not tanking the mpg's too much. so if 79 mph shows 29 mpg real time, ill try 78 mph. if that shows a bad mpg real time figure like say 30 mpg, ill try 77 mph and that may give me 31 mpg .... so on and so forth
Old Jun 18, 2019 | 05:22 PM
  #113
over40pirate's Avatar
I usually average 36 mpg in my Fit
Took a 30 mile trip, with 55 speed limit, and 1/2 of the trip was up and down 2 mountains.
Figure it would kill mpg.
Wrong! 44 mpg.
Used no gas coasting down the mountains.
Old Jun 18, 2019 | 06:36 PM
  #114
User1's Avatar
TIP:
Agreed with on all your points. When doing my driving, just about all the driving is at an elevation that doesn't change. Bout the only change is going over an overpass. I think the one thing that really makes a difference is that you're rolling on 16" tires right? I'm on 15"s.
Old Jul 31, 2024 | 05:59 PM
  #115
Doctor X's Avatar
I've only had my Fit about 2 months and here are my findings. All are combined city and highway but the last two was 75% highway.
38.X I forgot the exact decimal, but we'll just say 38.5
44.6 and I was pleased to see that.
45.98 After the 44.6 I started driving as conservative as possible, coasting down hills and all that stuff. I was bummed it wasn't 46 I topped it off to the max just to be consistent, had I quit one click earlier, it would have been 46.
Over 40 is pretty good for any car, but then again, I had a 91 Civic wagon with a 1.5L manual and it got 41 all the time no matter what. Plus I've driven stick shift all my life, so I'm pretty smooth with it and that helps.
Old Aug 1, 2024 | 05:33 PM
  #116
Sapper's Avatar
I also had a 91 Civic Wagon. I took my driving test in it. It was gray, the ugliest car I’ve ever owned, and had no power steering, but it did average 38-45mpg all the time.
AppleMac*Fit
Aug 1, 2024 11:53 AM
NotBlake
Sep 22, 2020 05:16 AM
Boba Fitt
Aug 3, 2013 08:29 PM
spin out
Jan 17, 2012 11:36 PM
12vltfrk
Aug 21, 2011 09:47 PM
