Braking fears
Old Feb 13, 2008 | 01:51 PM
mahout's Avatar
After you mentioned your concerns I took my Fit to the skid pad where we can water it down. The Fit ABS is noisy but I relate that to the Fit's lightness. Of course it takes longer to stop;ABS won't change the coefficient of friction between tires and road. It's sole purpose is to keep it driving IN THE DIRECTION YOU ARE STEERING. The 'grinding' noise is the repeating applying and releasing the brakes. With the wheels not locking the wheels will turn to maintain their direction, which a stationary wheel won't.
In the old days we used to practice what was called theshold braking which meant applying the brakes just hard enough to slow but not so hard as to lock the whhels and skidding who knows where.
In slippery conditions just drive slow as you can to maintain direction.
Old Feb 13, 2008 | 02:07 PM
xorbe's Avatar
it's unfortunate that the abs noise is in fact so startling on the fit. just keep braking, the brakes are working fine.
Old Feb 16, 2008 | 12:26 PM
NMG's Avatar
NMG
Exactly! It sounds horrific, but that sound and the feedback from the brake pedal also lets you know that the ABS system is working. Let it do it's job and just slow down in icy conditions. The less momentum you have, the easier you'll stop.
Old Feb 17, 2008 | 08:39 PM
Piotr303's Avatar
If You wont to stop more effectywly on the Ice, buy new tires for example Michelin Michelin Pilot Exalto A/S prabobly have some good one for all sezon. Second, if you try to stop on the ice and ABS kiks in Don't press the brake so hard this will make less abs work on relesing the weel and the tires will have more contact with ground or ice (but this improwes braking only marginally)
Old Feb 22, 2008 | 03:59 AM
storm88000's Avatar
Frequent FitFreak Poster
Originally Posted by greekdaddy000
they are too sensitive in my opinion....just driving over simple bumps with your foot on the brakes activates the ABS, I NO LIKE
I agree with you there. It's annoying for the ABS to kick because you hit a pothole.
Jimmmmmy
Jan 24, 2011 12:02 PM
Chairman Kaga
Sep 14, 2009 02:29 PM
Turon
May 30, 2007 03:57 PM
Jimmy101
Sep 14, 2006 01:05 PM
p1driftfiend
May 19, 2006 07:17 PM
