New Mod Made ***7mpg***
Old Mar 17, 2008 | 07:50 PM
08FitSport's Avatar
Originally Posted by Sid 6.7
And here is where the sensor was sitting before I installed it into the bend. It was wedged in between another couple of wires, so it wasn't dangling around.
Not really anywhere near the exhaust manifold.
This is scary, the sensor cools down as air get sucked pass it. The greater rpm the greater the cooling and the more gas it supposed to tell the computer to send to the engine. Yes, gas milage might be better but lean is hot and harsh on the engine. Drill that hole get that sensor in that wind tunnel.
Old Mar 17, 2008 | 08:02 PM
AppleMac*Fit's Avatar
Originally Posted by 08FitSport
This is scary, the sensor cools down as air get sucked pass it.... Drill that hole get that sensor in that wind tunnel.
He already did.... https://www.fitfreak.net/forums/eco-...tml#post255826
Old Mar 17, 2008 | 08:09 PM
cavie187's Avatar
I say leave the IAT sensor out and buy a wideband to see what you are running for a AFR.... though i doubt it will happen seeing as you made your own intake as opposed to buying one and a wideband and sensor is around $350. Still would be nice to see the results.
I am pretty sure you would be leaning it out slightly (probably not enough to hurt anything in the short term).
....and just to clear up some other questions.. If you did lean it out .4-1.1 points you will probably be seeing an INCREASE in hp. Not a drop.
Old Mar 17, 2008 | 08:10 PM
osborne's Avatar
My MPGs have been all over the place with my SRI installed. The only thing that really concerns me is that I have never gone below 33 MPG and I am now hitting 30 with almost zero WOT and 90% highway at 70MPH.
I went ahead and added another 90° bend to see if it would make a difference. So far I have noticed a change in sound and the throttle response seems a bit more reactive when I depress the gas pedal.
Old Mar 17, 2008 | 09:32 PM
pcs0snq's Avatar
Scan Gauge can be set up with X gauge to read the O2 sensors on most cars but not the fit now. They are working on the Honda codes.
Old Mar 17, 2008 | 10:09 PM
Sid 6.7's Avatar
Why so serious?
Finally someone who understands!
Old Mar 19, 2008 | 04:55 AM
storm88000's Avatar
Frequent FitFreak Poster
Originally Posted by pcs0snq
Am I the only one going huuu on the 22% increase? with an air filter change?
In general, statistics are treacherous ground. I tend to recall a study that claimed those who eat lobster regularly had a lower heart attack risk than those who didn't, which makes little sense because lobster is high in cholesterol. The cause of the lower risk was shown to be that those who can afford lobster on a consistent basis also have access to better medical care and various other benefits that are naturally linked to a high SES (socio-economic status.)
My point? There are often several factors that can vary any given outcome. In this particular case, perhaps driving style, or maybe the old air filter was dirty/clogged. Remember correlation =/= causation, neccesarily.
Old Apr 1, 2008 | 11:22 AM
RichXKU's Avatar
I agree with Jordan, I'd have to see multiple tanks before and after with the same driving style.
Many hypermilers put hot air intakes such as that on their car during winter for better fuel economy, but considering when the post was made, and the OPs location, that huge jump can also be attributed to warmer spring temps, and the shift back to a summer gas blend at the pumps as well.
Old Apr 1, 2008 | 05:22 PM
Sid 6.7's Avatar
Why so serious?
Amazingly enough, it was the same temps in Memphis and in Gulf Shores when we drove there. For the rest of the week it was 20 degrees COOLER at the beach than it was 400 miles north in Memphis. Some crazy weather.
Old Apr 2, 2008 | 01:17 PM
cavie187's Avatar
HA!!!
Try living in Wisconsin.
Old Apr 2, 2008 | 07:22 PM
pcs0snq's Avatar
Stock, I could not get over 35-36mpg even with an empty car on the highway. Around town, driving aggressively, I've gotten as low as 20mpg.
A few days ago I put on my home made $40 short ram.
I was on the road today for 8 hours heading down here to Gulf Shores from Memphis. At one point with some slowing and speeding (and a burst to 100mph to pass a couple trucks) but setting cruise at 75mph, I got 40.5 mpg with about 500lbs total baggage and people. AMAZING!! I never got over 36mpg before this.
Then after that, on a more stable portion about 150 miles long, set at 75mph, I got 43.8mpg!!!!!! I am shocked and amazed.
So it's been a month. IS it still true you saw a consistent +7mpg increase with this change?
Would you mind listing a few fills woth of mpg before and after the change
Also a retraction of the 7mpg claim is OK for sure. I'd make the change right away if it was verified real with real data.
Old Apr 9, 2008 | 03:38 AM
  #32
flyellow's Avatar
...yes, any updates to the install and mileage
Old Apr 9, 2008 | 08:51 AM
  #33
Sid 6.7's Avatar
Why so serious?
It appears my wife is averaging about 25-27mpg here in town, she's been driving it more than I have since we've been back in town. But this is a definite improvement. Sometimes, it's hard to tell, because she fills up like $5-10 at a time. She doesn't fill all the way up. Arrrggg!
Old Apr 9, 2008 | 09:24 AM
  #34
CptanPanic's Avatar
We need someone with a scanguage to definetly see the change in GPH at certain rpm's with a SRI. I do plan on trying it out in the next couple of months, but until then anyone else with a SG?
Old Apr 11, 2008 | 09:56 AM
  #35
pcs0snq's Avatar
I have a SG but like has been said many times, the instanious readings move around a great deal and it's almost a guess to say how they change real time. The trip and tank avg are rock solid.
BTW I see you are in Lake Worth. Did you get your windows tinted yet? I want to and was looking for a place around here that has done Fit's and has a decent price. I see the film for sale pre cut on ebay cheap, but was thinking the $200 for a pro to do it would be worth it if the place has been around and looks like they will be for some time in case it fails and needs to be replaced for free.
back to the thread
IMHO
... in summary, it looks like the 7mpg was not something available to any of us unless you are willing to risk changing the Fuel Air ratio and you engine. It's disappointing to see post that state big improvements that have not been fully proven before plastered on the form to be dis-proven.
Old Apr 11, 2008 | 10:21 AM
  #36
Sid 6.7's Avatar
Why so serious?
IMHO
What do you mean not fully proven statements and then plastered to be dis-proven? That statement makes no sense at all.
I for a fact went from 36mpg to 43+mpg and the only change I made was the SRI.
Now as for the reason that happened, I would guess people have their own opinions on. But the fact remains I did improve my mileage and so far, the in-town mileage has improved as well.
Old Apr 11, 2008 | 10:28 AM
  #37
pcs0snq's Avatar
OK let's just see what you really did.
How many tanks did you you see this change ? Tanks before and tanks after?
What was the Fuel air ratio with the air sensor not in the right place?
Old Apr 11, 2008 | 10:34 AM
  #38
Sid 6.7's Avatar
Why so serious?
On 4 fill-ups going down to Gulf Shores and coming back I got between 40-44mpg each and every time. That was averaging 73-76mph, 2 passengers and 300lbs of luggage.
Prior to that, on 6-7 trips between Memphis and Little Rock Ar, I averaged 35-36mpg no matter what the speed or amount of luggage.
I did not have an A/F meter installed, so I cannot provide A/F data.
As was stated though, I did check the spark plugs after the trip and did not see any signs of detonation or a severe lean condition.
Since coming back to Memphis, I installed the IAT in the OEM spot on the SRI. My wife has been driving it mostly since then and getting partial fillups, but I did fill/drive/fill on one occasion and saw a 26mpg in-city spirited session. Previous in-town driving had ranged from 19-24mpg at the most. I have not since been back out of town on the highway to re-test the highway mileage.
Old Apr 11, 2008 | 11:50 AM
  #39
pcs0snq's Avatar
Is the "7mpg improvement" from the Air filter and pipe as 1st stated or the lack of factory location on the IAT?
I think everyone would like to see a +7mpg improvement, but it's hard to still see what you did that made the gain and as you checked using totally different routs making it an unfair comparison.
How would you feel if a user read what you posted and made the change and hurt the engine with the IAT not factory or saw no gain at all?
Old Apr 11, 2008 | 12:26 PM
  #40
Sid 6.7's Avatar
Why so serious?
I refer you to my earlier posts:
The IAT wire is very short (maybe 2"). It was never at any point "hanging somewhere by the manifold".
For the sake of argument, why is running a little leaner a bad thing? It's bad for a forced induction motor, right? Yeah. You want to run fat with a turbo, close to an 11-11.5:1 a/f. When I was tuning my AEM EMS on my 1991 Eagle Talon AWD, I was shooting for an 11.5:1 a/f on my AEM WB-O2. At 20psi on my GT30R and 20 degrees total advance, on 93 octane, I made 470whp. I would have made a few more horses with more timing, or leaning it out, but I would have reached the limit of my Precision 750hp intercooller and started knocking. So I played it safe.
But in an all motor setup, a lot of guys I've seen tune for 13-13.5:1 a/f. Running lean is not a horrible thing.
And regardless IF, IF the car was running a little leaner than before, this motor is a 1.5 liter, low compression, naturally aspirated motor making 85whp. Running 93 octane gas. I couldn't get knock if I hit it with a 10lb sledge!
And IF, IF I traded 5 whp, for 7 more mpg, WGAF? I'll trade 5whp on the highway for 7 more mpg anyday!
The sensor was reading air temps up near the top of the throttle body, under the hood. The SRI has a 90 degree bent tube with a total length of 6", sucking in UNDER-THE-HOOD AIR. I seriously doubt there was much of a difference in the temps at the IAT and the TB.
But, I mounted my IAT in the SRI today using a 5/8" hole saw bit and the factory rubber grommet, so we will now see if that helps/hurts.
Already done.
And I simply did not have the time before we headed out of town to mount it in the bend.
I would recommend to anyone, do it the right way the first time.
Coppatop85
Feb 9, 2014 08:09 PM
wil524
Feb 15, 2011 02:29 PM
WillrunifChased
Dec 29, 2008 10:42 AM
moxiegirlRD
May 10, 2008 12:48 AM
Sid 6.7
37
Mar 12, 2008 08:24 PM
