Finding a K-series?
Old Jul 8, 2008 | 05:31 PM
SLrocket's Avatar
Finding a K-series?
How would you go about getting one?
Would it pass inspections?
How much approx. would it cost to buy and install into a fit?
Old Jul 8, 2008 | 05:34 PM
JDMchris.com's Avatar
I run THIS
please use the search function. You will find all of your questions using it.
https://www.fitfreak.net/forums/fit-...iscussion.html
Old Jul 8, 2008 | 05:35 PM
SLrocket's Avatar
thanks...you can close this down.
Old Jul 8, 2008 | 05:36 PM
shazaam's Avatar
http://www.hmotorsonline.com/shop/sc...Engines&hit=10
I guess those guys are reliable. There's alot of importers for jdm versions and you can usually get usdm versions from the same companies. Just google for purchasing engines...usually searching "jdm 'engine name' " comes up with results easily.
Old Jul 8, 2008 | 06:00 PM
SLrocket's Avatar
actually keep this open. there wasnt much direct info in that thread. interesting nonetheless.
in addition to the engine block itself, i will be needing a new tranny and exhaust system?
Old Jul 8, 2008 | 06:34 PM
SLrocket's Avatar
actually im very very interested in the R18 from the civic now.
Old Jul 8, 2008 | 07:13 PM
Fitftw's Avatar
no matter what swap you do, it's gonna cost big bucks, and a lot of custom work.
Old Jul 9, 2008 | 03:17 AM
shazaam's Avatar
yea, and you will need a new tranny and exhaust. It's...well, IMO almost not worth it unless you own/work for a tuning shop that does this kinda stuff but, lol for the money you'd spend(buying a fit and a k20+labor for it/time you spend and all the custom stuff you need) you could prolly find an rsx or even just go witha civic si.
o yea, if it's jdm engine...prolly won't pass smog n stuff of the sort, if its ausdm then you could get it too.
Old Jul 9, 2008 | 04:33 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah for sure,
i mean, seriously, if you could just buy a k series engine and install it like nothing, with all that money..
as yourself this question:
why am i driving a fit?
go buy an STi hahaha!
Old Jul 9, 2008 | 01:03 PM
SLrocket's Avatar
well i just really like the fit! and maybe once the civics get a bit older i will swap in an R18. enough power for the weight of the car and MUCH better gas mileage.
Old Jul 9, 2008 | 01:05 PM
shazaam's Avatar
Originally Posted by kyle.
yeah for sure,
not for gas mileage anymore cept...someone told me that some ppl who drive their fit with a k20 and drive ummm respectively actually get decent mpg.
Old Jul 9, 2008 | 01:10 PM
mahout's Avatar
There are several sources for used Honda engines; the instakllation might not pass inspection if the inspector knows what he's doing. I believe the law states replacement engines must be of the same as the original. Most of the time, unless the emissions tests fail, the inspectors don't care. In most cases its likely the emissions tests would fail.
Old Jul 10, 2008 | 11:14 AM
hiroko12's Avatar
Really, this makes no sense. Why buy a Fit, then gut it and put a K16 or 20 in it? New Tranny also, exhaust, brakes. Your running close to 30,000 or more. If you have the need for speed by the MS3/STI/EVO.
Old Jul 10, 2008 | 05:26 PM
TurboManGT's Avatar
I guess some people like to be somewhat different. Or have the built not bought mentality. I am one of those people. However I would never do anything as crazy as a swap to my fit. Its daily driven and I need it to be reliable haha
Old Jul 10, 2008 | 06:29 PM
a k20 would be relatively reliable right?
Old Jul 10, 2008 | 08:19 PM
TurboManGT's Avatar
Well I mean the setup, not so much the motor. But more the ecu, etc. etc.
Old Jul 11, 2008 | 01:38 AM
shazaam's Avatar
Yea, I'd love to do a swap on a fit...but yea. I wouldn't use a brand new car unless of course I worked for a perf. shop that does it mostly for like publicity/sponsors n stuff like that. But if I was alone on it I'd rather just get an older car and do it Or buy a more powerful car/one with more potential straight up.
TO_FIT_OR_NOT_TO_FIT
Nov 3, 2006 08:32 PM
daviddahlb
Aug 29, 2006 01:21 PM
atlas
Apr 22, 2006 10:25 AM
David Barnett
Sep 2, 2005 03:34 AM
