Aerodynamics
Old Jul 28, 2012 | 07:09 AM
TheRegulator666's Avatar
Aerodynamics
Is it just me, or does it seem like when driving with the windows down I'm going to get blown out the other side of the car from wind?
Old Jul 28, 2012 | 07:33 AM
Dwalbert320's Avatar
Door visors help and are popular with FitFreaks. At higher speeds fuel economy is better with the windows up and the AC on. At lower speeds, the best fuel economy is with the windows down and the AC in the off position.
The take away message here is that wind tunnel tests conducted by Honda are carried out with the windows up. The car was meant to be driven with the windows up.
If you only have one window open then you will experience a known aerodynamic effect called cavity resonance. It is also a problem for aircraft with landing gear bays and bomb bays. The air passing over the open window forces the cavity, in this case your car interior to resonate. Just like blowing across the top of a bottle.
The easiest way to stop that resonance, other than closing the window, is to crack the opposite front window...
This happens in every vehicle but some have it more pronounced. I would say the Fit is no worse then any other car out there!
There are several types of door visors available to purchase from a variety of sources.
Old Jul 28, 2012 | 08:58 AM
running's Avatar
When the two rear windows are about an inch opened with the others closed I get a pronounced acoustic vibration, almost like a wha - wha -wha thing going on, loud too
Old Jul 28, 2012 | 09:57 AM
A little "light" reading for a saturday morning. Many apologies in advance. But it does explain it perfectly and it gives an example using a car about half way down.
Cavity Flow Physics
Old Jul 28, 2012 | 10:06 AM
fujisawa's Avatar
Hahahah .. yeah, wear your seat belt and don't put the windows all the way down. It has big windows and you sit closer to them than in a big SUV say.
Old Jul 28, 2012 | 10:09 AM
Originally Posted by fujisawa
wear your seat belt
hahahahaha love it!
Old Jul 28, 2012 | 12:03 PM
running's Avatar
Maybe I'm a nerd, but I thought that was an interesting article. I am an aircraft mechanic too
Old Aug 5, 2012 | 10:04 AM
SportMTNavi's Avatar
We recently suffered a total loss of the blower fan during a long trip on a very hot (107°F) day (https://www.fitfreak.net/forums/2nd-...igh-speed.html).
We tried every combination of open or partially open windows. It was like a walk through a hurricane. Since the A/C compressor would still run, I tested the theory that by cracking some combination of windows the airflow would pull enough outside air into the car through the ductwork to at least cool it a little. It was like riding in some kid's car that's all speaker with the sound turned up. We never did find a tolerable noise level with windows open at all—and not much cool air sucked through the ducts, either, for that matter.
Cheers.
Old Aug 5, 2012 | 10:34 AM
Texas Coyote's Avatar
Cheers.
It's a shame that air vents into the interior went out of style with tail fins and Studebakers... I have Mugen style vent visors on my 07 GD3.. They redirect the airflow away from the windows and reduce noise and buffeting.. With the windows 1/3 of the way down at 60 or 70 it is possible to hear the radio and carry on a conversation without straining your vocal cords....
haudoodles
Sep 25, 2014 10:38 AM
dnamsterr
Jun 7, 2010 11:46 AM
td
May 23, 2010 03:30 PM
davejulien
Mar 31, 2009 03:33 AM
benfal2001
May 24, 2006 12:48 AM
