AC broken and they want $1700 to fix
Old Oct 25, 2016 | 01:12 PM
bob89's Avatar
Have you tried a simple AC recharge yet? (just to rule it out) It's really easy to do and is something you can try by yourself.
Old Oct 25, 2016 | 01:18 PM
eGadgetGeek's Avatar
Originally Posted by x_25
Yeah, this car has needed a supprising amount of survice (for a honda, almost nothing compared to my subaru). The clip was horrid since it was way down in there with nongood way to get to it. I wished it had just gone flying.
What year, 2007? I've been lucky with mine. I've only had to replace the alternator and the A/C clutch & pulley. Still running original rear brakes and have only replaced the front pads twice. My wife said I should look at replacing it but I told her that I have finally become one with my car. Her reply was that she's still waiting for that to happen with her.
As far as the inner clip, I had to buy a bigger pair of snapring pliers in order to get it to open enough to get it out. Once I had them, it came out rather easily. Getting it back in was a little tricky making sure it was completely seated.
Old Oct 25, 2016 | 01:23 PM
x_25's Avatar
It's a 2011. I had to do the HVAC fan resistor pack under warentee at 26k, the AC Clutch compressor coil at 65k, and need to do a strut bearing now at 80k. Just did the front brakes. I do drive it hard sometimes though, it has seen a track day and two autocrosses (when my miata is down for repairs, which is not often, I will take the Fit to events).
I bought bigger pliars but they didn't fit down in there was the issue. Had to fish it with screw drivers.
Old Oct 25, 2016 | 01:32 PM
Do you know where yours was built? My 2007 came from Japan. I know some of the latest ones in the states are being built in Mexico and had quality issues. I have run mine hard since day one. I drove a Dodge Intrepid before this so my getting on the highway style didn't change. It is actually more fun in the Fit taching it up to 6k before shifting and being at highway speed in 3 gear knowing you have 2 more gears for potentially more speed. I've paid more in speeding tickets than major repair replacement parts. I have started taking it a little easier on it. I would love to do autocross with it but I have too many other hobbies and kids sucking up my cash flow. I have thought about going up to Mid-Ohio Raceway for one of their open track days but haven't gotten around to it.
Old Oct 25, 2016 | 01:36 PM
x_25's Avatar
Yup, built at the Hiroshima plant in January of 2011. Car #12 for the year.
If you get a chance, do take it to mid ohio. I hear that track is a lot of fun and it is on my list of tracks to drive some day. They just finished up the SCCA run offs there the other week. I mostly run at pocono.
Old Oct 25, 2016 | 01:40 PM
My best friend works for Honda at the engine plant here in Ohio. He took me to the IRL Race there a couple years ago. It looks like a fun track. He's been on it several times in some of their test cars. I'll have to talk him in to going along. One of the benefits of having him as a friend, he brings the pre-production models home and takes me for rides in them. Got to ride in the new NSX this past February and the Type-R back in August. They both were a blast. I haven't been able to talk him into letting drive any of them yet.
Old Oct 31, 2016 | 04:38 PM
Bethsarim Catherine Tromp's Avatar
Exclamation How to videos?
So, I stumbled upon this thread as I was considering selling my 2003 Fit.
It has shy of 91k miles on it now, It's been a great car, save for the cosmetic things I wanted to fix later. (My own doing) it is the most economic car ever vs. comfort, even without A/C.
I'm likely the third owner, not sure.
But... Every time someone calls to see it I get second to tenth thoughts then the horn gave out. That led me to need a mechanic to look at it.... No one was available, so I started googling...
And now I feel like I should learn to work on my Honda myself.
Does anyone know where I can learn to troubleshoot that clutch coil?
I was also told I needed at least $1300 to fix the AC cause they claim it was the compressor. a second opinion with my fiancée and his dad and suddenly it was the thermostat. I backed away slowly without blinking and told them I am happy saving loads of cash on gas... And left it be...
Truth be told no one that looked at it likes to work on Honda, they only have negative things to say, but this is my dream car for my current place in life.
I was looking to sell it to get some cashflow for my business, but I keep getting a gut feeling it's the wrong call. I am looking to learn because this car already taught me how to change HID lights ( which my fiancée shat on saying they were exceedingly expensive, oh he generally hates my car, and we are now married anywhoo... I wanna show him I was right this car was my best choice)
So, guys, who knows where I can learn to check the darned clutch coil ( with AC I can ask way more for the car, or enjoy it better ).
Old Oct 31, 2016 | 10:17 PM
n9cv's Avatar
The very first thing you need to do is check the refrigerant level. if that is empty then the clutch will never be energized. Once you determine that there is some refrigerant in it, then start it up and turn the AC on full cold with the fan on full speed. Raise the hood and observe the clutch and compressor shaft. Is the clutch turning the shaft or intermittently turning the shaft - meaning cycling off and on? If the answer is no then you can proceed to diagnosing why the clutch is not working.
I would put a volt meter across the clutch coil to see if there is plus and minus 12 volts being applied to the coil either intermittently or all the time while the engine is running and the AC is on full. If there is 12 volts across it and the clutch is not turning the compressor shaft then you have a clutch problem.
I would next unplug the leads from clutch and put a ohm meter across the clutch coil. If it reads 30 ohms or less, then the coil is OK and you need to figure out your clutch mechanical problem.
I have read but never done this, but many people report that they have found the clearance between the clutch plates is sometimes too wide. They remove the clutch and remove one of the spacer bushings. Then when it is reassembled, the air gap is now much closer and the clutch works.
That ought for now to get you started.
Old Oct 31, 2016 | 10:20 PM
This is the website I use for all my cars. It It probably won't help you since it it doesn't have a 2003 Honda Fit. I I would look for a similar website that has.your cars. THe one I use gives step by step on troubleshooting and repairimg.
Old Oct 31, 2016 | 11:18 PM
ezone's Avatar
I don't have a wiring diagram for a Fit/Jazz that old....so most of this is assumptions based on how Honda set up other cars:
On most of the cars, if there is sufficient freon in the system to allow it to run, the radiator fan(s) will turn on when you try to run the AC. If the freon were empty the fans would not kick on when you turn on the system.
It may not have the correct amount, may not be enough to cool real good, but at least 40 PSI in the system is enough to close the pressure switch contacts and enable compressor engagement.
If the radiator fans kick on when you try to run the AC BUT the compressor does not engage its clutch, then I would look to the clutch relay, the clutch air gap, and the clutch field coil.
A good field coil would have 3-4 ohms resistance, not 30 ohms.
If you energize the coil it produces a magnetic field which SHOULD pull in (engage) the outer clutch plate, but if the air gap is too large it may not be able to pull it in.
The item I can't tell from here is the thermal protector. Some only interrupt the compressor clutch operation (usually a single wire compressor connector), others are set up to interrupt the entire request signal to the PCM (usually a 3 wire compressor connector).
Old Nov 1, 2016 | 03:49 AM
n9cv's Avatar
Sorry about the typo. I thought I said 3 ohms. Go with his 3-4 ohms figure. That is what happens when you try to answer things on a cell phone instead of waiting until I got home on a real machine.
Jeff8bass
Jun 7, 2021 04:20 PM
redludesh
Jul 22, 2018 02:20 PM
laszlosujj
Jun 7, 2017 08:30 AM
fitit2010
Jul 9, 2013 03:08 PM
benlinus
Jan 4, 2011 11:28 AM
