Please Help. Fit or EP3?
Old Dec 4, 2006 | 05:07 PM
watermelonman's Avatar
Originally Posted by Ricepuddin
you do relize the Ep3 has a K20 in it.
That sort of goes hand in hand with exactly what I said, doesn't it?
all it would need is a head swap
To make an A3 into an A2? Not true.
Old Dec 4, 2006 | 05:21 PM
Ricepuddin's Avatar
Father of the Wasteland
? does the block and the hed not match up?
Old Dec 4, 2006 | 09:04 PM
They do match, but there's more to it than that. The pistons are definitely different. I've been told that the crank is also different, although the bore and stroke are the same.
Old Dec 4, 2006 | 09:35 PM
Ricepuddin's Avatar
ok good point, thats still cheaper then buying the whole engine.
ecu and tranny also
Old Dec 5, 2006 | 10:39 PM
peepod's Avatar
If you buy vehicles that were well taken care of, why not? Also, If you can get a 3-4 year old Si with low milage for $5,000+ less than the cost of a NEW Fit out the door and you plan on putting parts on it why would you not?
Originally Posted by sillypuddy
you comparing a used 3, going on 4 year old car with a brand new fit
-joe
Old Dec 11, 2006 | 01:26 PM
dsk's Avatar
dsk
Sorry i havent been reading up on this post lately, i had an issue that stopped me from making my car purchase. However i am back in the market and i may be thinking about something else.
Thanks a lot for everyones feedback...the Fit and Mini S still in my mind along with a few others.
Old Dec 11, 2006 | 01:27 PM
dsk's Avatar
dsk
Mods, please delete this post...as i had started a new one.
Old Dec 11, 2006 | 01:48 PM
fEPst3r's Avatar
I would lean closer to the EP, you can find cheap ones on EPhatch. With just AEM Cold Air/DC Race Header/HKS Catback i made 165whp and 136 torque, my average MPG was 25-27 and the highest i got was 33.
I upgraded to a Rev Hard Turbo Kit, sadly i still havent completed the install (needs injector clips soldered and guardian wired) and its been a month, school, finals, work is takin up all my time. I am still driving it, drives like normal but it starts spooling around 2800 and i feel it from 3200-4k before i shift. I havent pushed over 30% throttle and 4k RPM but from that 3200-4k it starts to pull quite nice. At this time i been gettin 29-30 MPG driving under 4k everyday. At 7lbs of boost ive seen 250-260whp and at 10 your good for 300-320whp.
It can also handle, overall a real fun car to drive, the shifter is wierd at first but once u drive it, youll love it.
Old Dec 11, 2006 | 03:15 PM
geoff2005's Avatar
id go with mini. cause im more of a handling person. cooper s u feel a pull also, they arnt that slow.
PhilCo
Jul 26, 2015 11:54 AM
88StreetDoc
Dec 25, 2011 12:08 AM
suboh
Aug 14, 2008 10:25 PM
liquid22
Jun 20, 2008 02:04 PM
dsk
Dec 12, 2006 03:08 AM
