Hoses at Gas Pumps
Old Oct 22, 2015 | 09:45 AM
SilverEX15's Avatar
Hoses at Gas Pumps
Why are gasoline hose on pumps so short now? Remember the good old days when you could park on either side of the pump to fill your car? Now you see a line of cars waiting on one side, while the other side of the pumps is empty. Stupid! Was this a safety issue, or are they just saving money on hoses?
Old Oct 22, 2015 | 10:33 AM
thewebgal's Avatar
Drive around the island and come in from the other direction??
doesn't seem so difficult ...
But I think short hoses may have to do with Vapour recovery systems and such...
Old Oct 22, 2015 | 10:35 AM
Milano Pink's Avatar
I've noticed that some pumps appear to have short hoses but there is part of the actual pump that will extend out. It works like a keychain you might see on a janitor. They have these at the Costco I go to, and it makes the wait much shorter. You typically have to hold the hose over the car to avoid it touching the paint (or maybe denting the roof on the GK).
Old Oct 22, 2015 | 10:50 AM
SilverEX15's Avatar
It's often impossible because of tight quarters and cars in the way. Halfway through the maneuver, someone will drive straight in a take the spot you were aiming for. I can sometimes do it with the Fit, as I did this morning, but it's not a simple solution. I've seen drivers drive by stations where they had to wait.
http://www.kwwl.com/story/25992788/2...-way-too-short
Old Oct 22, 2015 | 10:56 PM
GeorgeL's Avatar
I remember when gas fillers were centered in the rear, you'd open the license plate to fill the tank!
Of course, the explosions weren't good.
We have a station here that has signs that say "nozzles reach either side" but that only applies with subcompacts, and only then if you sidle right up next to the pump.
Old Oct 23, 2015 | 08:36 AM
SilverEX15's Avatar
The exhaust is usually on the left and the filler on the right. They can't fit both on the same side of the car. The center-fill was a compromise. Cars in the 1950's often had the filler hidden inside a taillight, or something similar.
Old Oct 24, 2015 | 06:29 AM
Black3sr's Avatar
I used to pump gas back in the early 60s. A challenge to find some of them. 56 Chevy was neat how the taillight would swing out.
Old Oct 24, 2015 | 07:04 AM
SilverEX15's Avatar
The 50's Cadillacs had a similar system.
Old Oct 28, 2015 | 08:49 PM
GeorgeL's Avatar
And early VWs filled under the hood, with a filler wide enough that you could fill the tank from a bucket if you needed to. Oh, and when the tank was full it was full, none of this nozzle shutting off with a gallon of space left in the tank! :)
dennis4558
May 21, 2016 06:48 PM
davela72
Nov 13, 2011 09:47 AM
eddie777
Mar 4, 2009 01:46 PM
pcs0snq
Jun 24, 2008 11:40 PM
MajorWang
Mar 22, 2007 09:23 PM
