Racing A place to discuss upcoming and past Fit racing events.
Tracking/AutoX Discussion
Old May 1, 2015 | 08:04 PM
  #441
yovtecjustkickedin's Avatar
Impressive.
Think the general consensus is the Mazda2 is the better racing
chassis.
Good luck!
Old May 1, 2015 | 09:46 PM
  #442
JN2k108's Avatar
Originally Posted by yovtecjustkickedin
Impressive.
chassis.
Good luck!
not necessarily. My fit was not fully prepped for STF. If I had stiff coilovers, bigger rear bar, intake, high flow cat and exhaust, I could have easily beat the 2. Those guys were lowered and had the better set up. I know I'm the better driver and it was my first time in the Fit!
Old May 2, 2015 | 01:05 AM
  #443
Rollerboots666's Avatar
Originally Posted by JN2k108
NNJR was letting you do Pro Solo starts! OMG SO FUN!!!
This was my fastest scratch time with Grant Reeve in the car. I'm only running Sticker Z2 Star Specs (spec miata size) on Kosei K6R
NNJR Autox 04/26/2015 STF 9 - YouTube
You killed that slalom the first run! Also what was that noise? Sounded like you were dragging a jack or something. What size ZII are you running?
Old May 2, 2015 | 08:57 AM
  #444
Myxalplyx's Avatar
Interesting that you say this. During the 2nd heat that you were working and I took a break, one of the Mazda2 guys came over to talk to me. He mentioned that the guy that was driving the Mazda2 had a completely stock setup. I have to remember that some people's idea of completely stock is 'oh I only have an intake and/or exhaust' or 'Oh I'm only using drag slicks and aftermarket coil-overs'. I didn't dig for details. EVERYONE looked impressive to me as this is all new to me.
Old May 2, 2015 | 10:08 AM
  #445
apexanimal's Avatar
Originally Posted by ragingti
I went out and autocrossed for the first time in a couple years. The new RE71R's felt great. Last street tire I ran on was the old Azenis. I ended up winning STF, but the competition wasn't great. I was 33rd out of 128 raw time and PAX'd 10th of 128. All in all a good day. There was a Mazda 2 at a previous event that won the class, hopefully he'll be there next week.
North Hills Sports Car Club
how's the rear disc setup working for you?
Old May 2, 2015 | 11:38 AM
  #446
JN2k108's Avatar
Well both 2 look lowered but the faster 2 had the faster tires too. Those hankooks
Old May 2, 2015 | 06:44 PM
  #447
ragingti's Avatar
I did a few panic stops right after I did the swap and it was a bit scary. I ended up finding some air in the rears when I replaced the front hoses and flushed the whole system. It felt better after that. The course last week had a fast finish and it felt great. I don't think I've found the limit yet, no ABS engagement on course but the RE71R's are STICKY so I would guess the extra grip there is helping. I was concerned at first a different master cylinder may be necessary but it felt good at autox and while slightly different feeling on the street I think it's all working well.
Old May 2, 2015 | 10:12 PM
  #448
apexanimal's Avatar
Good to hear...
I'm still thinking about a master cylinder... Nothing soon but I'll be researching it a bit - from what I've seen there isn't a direct replacement for either a larger bore or rear disc one...
Old May 2, 2015 | 11:14 PM
  #449
Previc93's Avatar
I did rear disc on my fit and had to do the front setup because it had too much rear braking. The rear brake setup I have is the Fastbrakes kit. Now with the fronts done it is manageable to not lock up the rears too early but still does. I still have oem master cylinder and next step is plumbing the brakes without abs and with an adjustable prop valve. I'll run most braking up front and hardly any in the rear but with the adjustment in case of rain so I could put more in the rear.
Old May 3, 2015 | 07:03 AM
  #450
ragingti's Avatar
Didn't the JDM Fit RS come with rear disc? I had started trying to find a part number for a master cylinder out of one of those. It seems there are places to order OEM Japanese parts but figuring out the part number is the hard part. I'm guessing the ports would be on the "wrong" side being RHD, but nothing a few custom bent lines can't fix. Has anybody found a somewhat easy way to figure out JDM OEM part numbers?
Old May 3, 2015 | 09:11 AM
  #451
apexanimal's Avatar
^ that
10char
Old May 3, 2015 | 09:13 PM
  #452
ragingti's Avatar
Ran again today. The course and my driving were not so great. I finished 39th out of 120 raw time. 18th of 120 in PAX. Won STF again but same story as last week, not much real competition in class. The car felt good but I was struggling to find time on the course. Still a fun day!!
Old May 26, 2015 | 06:02 AM
  #453
JN2k108's Avatar
I tried again last sunday at Devens. I didn't do too well. Here's my fastest dirty
Old May 29, 2015 | 10:32 PM
  #454
2015 NER SCCA Points Event 4 Car 9 STF - YouTube
If you're using a GoPro I'd recommend getting a remote mic to cut out the wind noise on your video's. It really works well for reviewing your footage and listening to the engine.
Looked like you had some understeer with the sound of inside spin going in certain areas. I'm not sure on your set-up but try to get the car to rotate.
Old May 29, 2015 | 11:21 PM
  #455
Here's one of my co-drivers runs from last week.
Old May 31, 2015 | 08:41 AM
  #456
JN2k108's Avatar
It only has 205/50/15 Z2 Star Specs on Kosei K6.
Here's some rotation for you. First time with this setup and tires were at 35psi square. I lowered all of them to 31 font 30 rear. The car rotates all right, I would like some koni's.
Old Jun 2, 2015 | 12:18 AM
  #457
Mark your tires to see what pressure is best. Second if you want more rotation got the time being I would run the rears high. On RE-11A's with F8.5 R10K spring rates I ran F50, R40 psi. Now with RE-71R F10K, R14K spring rates I run F48, R42.
Old Jun 3, 2015 | 11:32 PM
  #458
charlie a.k.a. chuck's Avatar
If you only have wheels and tires, why are you running stf? Just curious.
Old Jun 4, 2015 | 08:28 PM
  #459
jhn's Avatar
jhn
If the off-set is greater than 6mm over OEM, it's enough to bump you up on that factor alone.
Old Jun 4, 2015 | 10:51 PM
  #460
Just bump the rear pressures up and you'll get better rotation on the stock suspension.
Because he is technically modded.
H class - Stock Fit
HS (street) - Stock fit with street tires only
STF - Wheels and tires (plus bolt-ons which he doesn't have).
STF doesn't have any restriction on wheel offset only tire width at 225.
