Yellow 1994 Integra
Old Mar 22, 2017 | 08:57 PM
  #61
Tied the front bumper into the frame.<br/>And the inter fenders reattached all round.<br/><br/>Then.....
These came, so that led to this.....
Old Mar 23, 2017 | 03:32 PM
  #62
Of course I can't install the flaps without cleaning, ha ha.
Take a last look at the 117k mile struts, coilovers with top hats are replacing them soon!
Which finally after the sun went down they're​ all on !
What a great night! And yep the fronts scrape ain't it great! ��
Old Mar 23, 2017 | 08:34 PM
  #63
Tune up: plugs, cap, rotor, wires.
Old Mar 23, 2017 | 08:40 PM
  #64
300 watts rms 600 peak *4 channels. Pyle 6.5" bass/ tweeter with crossovers, and 6.5" mid basses in the rear panelsstill look at the right stereo unit for the dash.
Old Mar 23, 2017 | 08:52 PM
  #65
Old Mar 25, 2017 | 09:20 PM
  #66
These will go at the very bottom of the grill. There are 2 plastic inserts there and the driving lights will fit right in.
Jeep Life, repair and rehung door. Replaced rear brake pads.
Old Mar 26, 2017 | 07:48 PM
  #67
Ben was kind enough to give me a rear wiper arm and motor, so clean, prime, and paint.[/I]
Yeah that's a wiper arm there, I cut and install the blades myself. I figured that with all the cars in our family this was a win win .I get refills at 28" for .60 a piece and at 2.00 to 17.00 for the assembly, what a savings.
Old Mar 26, 2017 | 08:02 PM
  #68
Action Jackson's Avatar
I used a longer flexblade wiper on the rear. I also installed a delayed rear wiper feature, so that it's not constantly wiping at its single speed (IIRC).
I briefly looked into, but didn't find much info, for a variable wiper stalk from the same Era Honda vehicle (like the Accord wagon, or Civic hatch). Not sure if it's been done yet.
Old Mar 28, 2017 | 08:37 PM
  #69
New stainless steel sparkplug wire cover prototype
Old Mar 29, 2017 | 08:46 PM
  #70
Recovering the arm rest
Original cover<br/>A little ratty and faded but for 24 years old not bad.
Carefully pull the cover off to make the template.
Sewing the seams together.
Test fitment.
Done
Old Mar 30, 2017 | 05:05 AM
  #71
axlline's Avatar
You do great work sir!
Old Apr 1, 2017 | 06:18 PM
  #72
Replacing missing OEM parts
Old Apr 1, 2017 | 10:30 PM
  #73
Adjusted fender and bumper skin to match up better
Added new fasteners and cleaned up others.
Old Apr 1, 2017 | 10:38 PM
  #74
Thank you!
I'm looking to returning this car to OEM with a few exceptions. lol. 🗾
Old Apr 4, 2017 | 09:33 PM
  #75
Bake at 200 degrees or until golden brown
Bake at 200 degrees for 30 min. to loose glue. Then be careful with a med. flat blade screwdriver gently pry catches out of the backing. There is 1 #1 Phillips screwdriver to remove where the side reflector is.
After cleaning mask it off and I used bright silver metallic.
I am using a black sealing mastic strip to seal it back up.<br/>Reheat @ 200 put just the housing in and when the seal is soft replace the lens and snap it back into the housing ,.... Carefully.
Old Apr 6, 2017 | 09:33 AM
  #76
mangosmoody's Avatar
wow coming along ways with the cleanliness
Old Apr 6, 2017 | 08:48 PM
  #77
That's what gets the good $, lol.
Thanks man,
Mike
Old Apr 6, 2017 | 09:00 PM
  #78
Driving lights: Test fit
So if ur not scard to take a 2" hole saw to your perfectly good front bumper, then here we go.....!
Here they are fresh out of the box. Collar is a little bit bigger than 2" . Which works out to the good as that way I could get a tight fit. There is a square cob in the light and I could not look at it when powered up. And the ring is bright white.
Measured and made a mark center and a little bit high as I want room in-between to clean the dirt out when detailing. BTJM.
Not the best shot of them but this is the test fit. Me likey!
The ring picks up the yellow of the paint. Which I wasn't expecting, but like.
Old Apr 6, 2017 | 09:09 PM
  #79
We had another close call with a tornado again today. I've been in the area for 57 + years and have only heard of a few in the area but this week we have had 5 touch down and tear up buildings and trees?!!
Old Apr 7, 2017 | 07:12 AM
  #80
axlline's Avatar
No doubt, I'm over this stupid weather!
