Yellow fog light vinyl film Installation, questions, answers
Old May 5, 2007 | 02:22 PM
  #141
aznguyen316's Avatar
I wonder how smoked would look =) I like the color of the foglights cuz they match my SSM and already have yellow bulbs in there. I guess I might have to give it a try. XPEL on their website doesn't have fog light alone so I guess I might have to just call.
Old May 7, 2007 | 05:34 PM
  #142
bestfit's Avatar
i got mine installed !!
Cost for X-Pel Protective film : 4x10 = $10.50 shipped.
Time spent on installation: about 20 min
having better protection for flying rocks...priceless ^^
Old May 8, 2007 | 10:05 PM
  #143
bestfit's Avatar
just drove at night time and it was awesome.
after installing flims, both of fogs were adjusted bit higher to illuminate road better
i like it alot. and it looks "cool"...
Old May 8, 2007 | 11:21 PM
  #144
Spule 4's Avatar
Originally Posted by George02
the yellow fogs arent gonna make much a diff in seeing at night
Well, there is an arguement as to yes and no.
Having owned French spec cars with yellow headlights and assorted cars with yellow fogs, in bad weather there "is" a difference to the human eye.
For more reading, try here:
Daniel Stern Lighting Consultancy and Supply
Old May 9, 2007 | 12:12 PM
  #145
tonejunkie's Avatar
The film would do a better job of protecting it from rocks, etc. than the paint, right? I've been thinking about doing this...
Old May 9, 2007 | 12:56 PM
  #146
bestfit's Avatar
Of course..i too was thinking to paint them then ... it is not just for "looks" but for "protection" as well..
also.. it is "quicker" to use flim than painting since there is no "wait" time.. ^^
DO it now.!!! when i took out fogs and cleaned them up with water/alchol.. i "already" found lots of scars/chips on fogs... they take abuse "every day"..
Old May 14, 2007 | 10:28 AM
  #147
mholmes85's Avatar
how do i paint foglights yellow?
i just purchased a 07 NHBP fit, Ive seen other fits with yellow foglights and i was wondering do they use a paint that goes over the light OR do you have to buy a the yellow piece seperate?
HELP and yes you can tell im a noob to forum...
Old May 14, 2007 | 10:43 AM
  #148
bestfit's Avatar
Old May 14, 2007 | 10:50 AM
  #149
mholmes85's Avatar
thank you, will be doing asap
Old May 17, 2007 | 04:36 PM
  #150
fithouston's Avatar
just noticed a decent amount of smoke from my fogs
i put the lamin-x film on about 2 months ago and this is first time seeing somke
not sure what to do?
Old May 17, 2007 | 09:34 PM
  #151
bestfit's Avatar
are you sure smoke was coming from fogs?.. could be a radiator fluid vaporizing????
Old May 18, 2007 | 12:53 PM
  #152
fithouston's Avatar
preety sure it was comming from both sides more from the passenger side and the smoke smelt like burnt plastic and the fog were hot enough to burn my hand
Old May 18, 2007 | 05:10 PM
  #153
Spule 4's Avatar
Stock H11 bulbs or higher wattage or H9?
There are some posts on other forums (Ford) about problems with the film breaking down.
Old May 19, 2007 | 01:52 PM
  #154
bestfit's Avatar
if you are using stock watt and it burns the filim then you should contact Lamin X for thier warranty.. i am sure they have something to say..
Old May 19, 2007 | 02:16 PM
  #155
etyc's Avatar
good to kno that im not the only one experiencing this smoke
Old May 19, 2007 | 05:23 PM
  #156
Spule 4's Avatar
What about the guys with the stained glass paint?
For those that painted their lenses, how is the stained glass paint holding up over time as far as heat and wear?
Old May 19, 2007 | 06:01 PM
  #157
leonine's Avatar
I painted mine and have had no problems with smoking lenses. The paint is holding up nicely as far as i can see.
Old May 31, 2007 | 09:00 AM
  #158
007FitNBP's Avatar
Thumbs up
well i just did this last night with the Lamin-X film and it came out great....would like to thank KoolKevin for the good write up and pics
Old Jun 4, 2007 | 10:43 PM
  #159
kenton's Avatar
Where to buy yellow pre-cut Lamin-X fog film?
Everyone says to buy the pre-cut.
No one tells me where to buy it. Please tell me
Old Jun 4, 2007 | 11:17 PM
  #160
JonasM's Avatar
I ordered mine directly from the manufacturer:
Lamin-x.com - Protective Films
$21.90 shipped for 2 pieces of yellow film. It turned out, with careful cutting, that I have enough for 2 sets of fogs, so I have some to spare in case I need a replacement.
If you can get pre-cut for the same price, then no big deal either way. Since the fogs are so easy to remove for fitting, cutting your own is very easy.
JonasM
