best spark plugs for GD?
Old 07-01-2010, 03:11 PM
Psycho_FIT's Avatar
I've been intermittently getting the CEL with stuttering. I was going to replace my coil packs and replace my spark plugs at the same time.
Which spark plugs are you using? Part #?
Who has the best prices on coil packs?
Old 07-01-2010, 11:00 PM
Type 100's Avatar
Don't you guys have iridium spark plugs fitted as stock on your GDs?
I'm running NGK BKR6E-11s...won't last nearly as long as any iridium plug but they're factory-recommended for my engine.
Old 07-02-2010, 10:13 AM
I'm using the Iridium sparkplugs that Oscar Jackson recommended for the GD3. Seems to work better than the stock iridiums and even showed a slight HP increase via dyno testing.
Old 07-02-2010, 02:14 PM
taFITta_sport's Avatar
yeah those are the same ones i am using. denso ik22's. does feel a little better and as for coils you can just go to the dealership. i think they are going to run about 70 each though. waiting to replace all of mines too.
Old 07-02-2010, 05:44 PM
Jensen Healy's Avatar
Which manufacturer are you using for them?
Old 07-02-2010, 06:58 PM
the one oscar is talking about are made by denso. they are denso iridium part # ik22.
Old 07-02-2010, 10:32 PM
Texas Coyote's Avatar
With Denso IK22s I am seeing ignition timing of over 40 degrees advance at time and almost always in the mid 30s.
Old 07-02-2010, 10:35 PM
jagass's Avatar
Same question here guys. Need to replace my spark plugs.
Old 07-03-2010, 01:17 AM
Now is that a good thing or a bad thing?
Old 07-03-2010, 03:11 AM
Yes it is good.... You burn your fuel more thoroughly, make more power and torque.
Old 07-03-2010, 04:37 AM
Jazzfitman's Avatar
The best variant for Fita of the first generation DENSO K20PR-U11
K16PR-U11
Old 07-03-2010, 07:11 AM
theFigsFit's Avatar
Good info here guys, thank you!
-Jesus
Old 07-03-2010, 09:27 AM
dewthedew's Avatar
ive run the denso ik22s before I had a s/c and now im still running them after i sold my s/c. Not a single problem. On the dyno we saw more power on the 2nd and 3rd run as it heated up, the tuner said that would be the ik22s
Old 07-04-2010, 12:07 AM
THEproFIT's Avatar
that's oscar's dyno correct?
Old 07-04-2010, 12:38 AM
Psycho_FIT's Avatar
If it advances your timing 40 degrees, do you have to make other necessary adjustments to compensate for the advanced timing?
Old 07-04-2010, 10:00 AM
apexanimal's Avatar
^the computer will redo the fuel and whatnot....
doing a intake/exhaust will help get the most out of that extra timing...
VelvetB
05-11-2016 06:59 PM
InsaneGenius
10-19-2015 11:05 AM
bellzGD3
03-21-2014 11:32 PM
spreadhead
03-11-2011 04:40 PM
Oofie
12-13-2008 11:13 PM
Quick Reply: best spark plugs for GD?
