DIY: Independent Fog w/ Original Switch.
Old Oct 6, 2008 | 02:55 PM
  #81
UN_FIT's Avatar
devil doc helped me with mine. easy 10 min diy!!! thanks again jon jon.
+1 rep!
Old Oct 6, 2008 | 09:51 PM
  #82
FitPilot's Avatar
Is this what you where talking about? A spade connector? I ended up using one of these in the #2 slot and it worked perfect. I will debate doing the relay so i can use them with the high beams on next.
Old Oct 7, 2008 | 04:23 PM
  #83
B1str0's Avatar
RubberBabyBuggyBumpers
i just did this ... used the add a fuse thingy bought some fuses and used some 18g wire i had laying around ... used blacktape and needle noses to pinch the wiring together .. took a bout 7 minutes lol and used fuse location 2 cuz it runs of the ignition PIIIIIMPPP
Old Oct 12, 2008 | 03:25 AM
  #84
Rubba Burna's Avatar
HID Addict
Man i cant wait to do this, not just for the independant fog lights but for the highbeams+fog lights. high beams have a narrow focus and dont show light in the near distance. fog lights fix that! one question tho, whats a "Connectors w/ wire crimper"? i want to avoid soldering, last time i did it, i ****ed up my ps2 bad... and is there anyone that might be avalible on AIM or MSN or sumone who is always on FF, cuz i think i mite have trouble grounding it maybe.. gunna try tomorow, or, today since its 3:30 in da morning -.- and is this reversable?
Old Oct 12, 2008 | 11:53 AM
  #85
FitPilot's Avatar
Just use an electrical connector to join both ends of the wires, or you can use a male/female plug. A crimper is a tool that you would use to squeeze the metal around the wire once the connector is in place on the stripped piece of wire. You can prob. get away with using a pair of pliars. You can google wire crimper and you will see what it is, you have seen them before.
Old Oct 12, 2008 | 12:30 PM
  #86
SickFit's Avatar
Originally Posted by fit4afit
Yes, i would like to know if this also apply to the 09 fits. @_@?? Thank you
I came back from the dead. I dont know if it applies to the 09s. Dont try it unless you know it will work.
Old Oct 15, 2008 | 03:16 PM
  #87
TimeTTackFIT's Avatar
have u looked into making there super independent as in they stay on no matter high s or low s? just curious but great post im putting on my shoes to do it now 0.o"
Old Oct 15, 2008 | 05:32 PM
  #88
pwnstar's Avatar
ok here is something i would like to know if anyone has tryed, insted of trying to squezzzzzz in under the dash and cliping the ground to the fog lights so when the high beams are on the fog lighst stay on also, has anyone tryed to just clip the ground going to the fog lights right at the light and grounding it on the front rad support or somthing? will this work? not sure if there is somthing im missing about this but i think it might work has anyone tryed this?
Old Oct 15, 2008 | 06:48 PM
  #89
HID Addict
ugh! im still confused about wat a connector is, is this like a copper clamp that goes onto a bare wire? can someone provide a pic of what this is? that would help me very much. and i have a feelin if i ask the guy "you have an any connectors?" hes gunna go what kind and all that shit. so what should i ask him?
Old Oct 15, 2008 | 08:53 PM
  #90
HID Addict
wow im so ****ing pissed PA got some stupid laws! i went to auto zone and asked for a connector and add-a-circuit (wire was bought at radioshack, gotta love em, dont know shit about cars, mostly). Hes like " huhhhhhh.... what are you talkin about" and this wasn't one of those teenager noobs there, ive seen him workin there b4. i had to explain him what i was tryin to do to my fit and he tells me its illegal. i looked around the store myself for the damn things and i got it, brought it to the counter, the same ****in idiot: "im denying you service for those items" **** me for denying service! bullshit! ****ing asshole got a shitload from my mouth, ended up leaving the store with just my keys... no add-a-circuit or connector -.- no offense to anyone but i hate PA check your state law b4 u mod ur stuff
Old Oct 15, 2008 | 10:56 PM
  #91
madhartigan's Avatar
+2 on interest for the feasibility of this mod on the '09 Fit.
Thanks!!
Old Nov 7, 2008 | 02:24 AM
  #92
Tounge73's Avatar
Thanks!!
+3 on 09's
Old Nov 27, 2008 | 12:38 PM
  #93
HID Addict
damn -.- i bought the wrong connectors ****! can someone tell me what it's supose to do and what it looks like, and everything i need to know to get the right one. im going to go to Home Depot or Lowe's and get the connectors while im there, someone plz help me! help a guy in desperate need of a independant fog
Old Nov 27, 2008 | 03:01 PM
  #94
HID Addict
Bump!!!
BUMP! help me out
Old Nov 27, 2008 | 06:08 PM
  #95
heymikesays's Avatar
I just did mine. The first post really helped out with the pictures. Really easy. Thanks for the DIY
Old Dec 3, 2008 | 09:14 PM
  #96
HID Addict
Oh no!!!! Emergency!!! Help!!! >.<!!!!
oh shit... this is why i wanted to wait till a meet, got dammit. i was doing the mod to the end. and when i tried it... the fog lights didnt work and the Engine light was on and the airbag light was on [in the display] while passanger airbag was ok [meaning that light was off] and this is the worst part.... no cruise conotrol!!! me and my mom need it and we use it everyday >.< did anyone have this problem?!!? any idea what could be wrong? solutions!?!?! please help anyone!!! >.< i need to fix it tonight! onthe add-a-circuit, i see one 10 amp fuse, is that right? or is there two? if so where do i get the second red thing?!?
Old Dec 3, 2008 | 09:56 PM
  #97
same thing happened to me, disconnect your battery and let it reset your ecu, after reconnecting it, reset your radio and the light should go away. I also switched my relay location to slot 2 since it was an empty slot. Don't know if both of those tasks are required to take out the engine light, but it worked for me. gl.
  #98
pwnstar's Avatar
sounds to me like you cut the wrong wire might wanna go back and look you might have cut a different color.
Old Dec 3, 2008 | 10:53 PM
  #99
HID Addict
no it was a red-dominent with yellow stripes. looked at the pic and it was the correct one. heymikesays, did your fog work afterwards?
Old Dec 3, 2008 | 11:00 PM
  #100
Yes, afterwards no problem. I haven't tried the cruise control since thought but I will try it later. It's been about 2 weeks with no problems/check engine lights.
