DIY: Independent Fog w/ Original Switch.
Old Feb 23, 2010 | 10:43 PM
  #141
Scala's Avatar
Complete! great DIY! finished in 10 min! thanks
Old Feb 24, 2010 | 12:20 AM
  #142
Scala's Avatar
Ok fail, didnt work, i got the fog lights to work independently followed all the steps, but when i went to go turn on the car, none of the instrument panel worked (rpm didn't go up, mileage didn't turn on, gas gauge didn't go up)
after all that the engine light went on. idk why
so question, for the fuse relay thing, do you need an extra fuse? because i only used the one that was on #3
any help and tips would be appreciated
Thanks
Old Feb 25, 2010 | 06:41 AM
  #143
trainy's Avatar
Wow! I actually trying it.It is really impressive.
Thanks for the effort man!
Old Feb 28, 2010 | 02:10 PM
  #144
Rubba Burna's Avatar
HID Addict
Thanks
nothing againt u but thats actually pretty funni lmfao yesh you were suppose to get an extra fuse lol thats what the add-a-circuit is for. that add-a-circuit is suppose to go into a pre-exisintg fuse slot, then 2 more fuses would go into that add-a-circuit. kinda hard to picture it, you'd have to see it for youself.
Old Mar 2, 2010 | 02:58 PM
  #145
Scala's Avatar
yeah i figured that out the next day lol i was like fail!!!!
Old Mar 5, 2010 | 01:33 PM
  #146
bluebird07's Avatar
hi i did what you said first i locate that red/yellow wire and i cut it and connect the wire from the harness to the add a circuit wire and connect it to slot #3 just as simple right and it work perfect but how come my gas and rpm and mph gauge doesn't work? did i do something wrong here?? i need help! asap....
Old Mar 17, 2010 | 09:35 PM
  #147
1904-08-fit-sport's Avatar
goin wire this up this weekend!!!! Man independent 8K fog should look nice! thanks for the DIY and alll the researchthat went into this SICKFIT!!!
Old Apr 24, 2010 | 11:33 AM
  #148
Mr & Mrs Old Codger's Avatar
If I understand this mod correctly, you removed the + feed for the fog lamps from the low beam circuit, gave it another feed from the fuse box ( preferable switched ) and the - side is opened when the high beams are on? If so, slick and great work. I've been wanting to have the option of having the fogs on independant of everthing else except the ignition switch. One ?. Do the fogs have their own relay?
Old Apr 25, 2010 | 05:59 AM
  #149
feifei's Avatar
Does anyone know will this work on a RDX?
Old Apr 25, 2010 | 10:13 AM
  #150
I just did the mod as described by SickFit with a few other details added. I had some male and female bullet connectors and heat shrink tubing waiting for a project. The male was installed next to the harness connector and the female installed on the new wire from the fuse box. The make required no heat shrink and the female end has enough extending out to cover the crimp area of the male. A short piece of 3M #33 was added over the end just in case. With three screws out the lower half of the steering column cover comes off and the added wire can be neatly wire tied to the harness. Empty fuse position # 2 was used
I did notice one oddity while testing. If the headlights and fogs are on and the panel lights dimmed, turning off the headlight keeps the panel lights dim as long as the fogs are still on. If the fogs are turned on without the headlights the panel lights stay full bright. I can't see a problem with this but don't understand why this happens. There must be a relay somewhere that stays up as long as current passes through its contacts.
The fogs do go out when the key is off.
The fogs do go out when high beams are used.
The fog indicator on the panel works fine.
Thanks to all the guys and gals that risked a flaming Fit for coming up with this mod.
Old Jun 3, 2010 | 01:56 AM
  #151
chunkylover8200's Avatar
im confused, whats the point of this mod?
Old Jul 15, 2010 | 04:46 PM
  #152
ydnality's Avatar
has anybody tried this with the GE8 fit? If not, do you think it would work?
Old Jul 28, 2010 | 09:49 AM
  #153
HOLY FIT!!'s Avatar
glad someone made a new write up for this, will be doing this this weekend!
Old Jan 26, 2011 | 01:37 PM
  #154
SickFit's Avatar
I is back!!!!!
Old Feb 15, 2011 | 01:32 PM
  #155
Santiad's Avatar
quick question : can I used this great DIY on a GE8?
the DIY for the GE8 has way more steps I rather not do...
Old Feb 16, 2011 | 08:01 AM
  #156
SickFit's Avatar
Do not try these steps on the GE8. There are many more steps involved.
I will see if I can find an easier way.
Old Dec 1, 2011 | 02:52 AM
  #157
kcle730's Avatar
Going to attempt this soon!
Just to get this straight! Using an ATM Add-a-circuit WITH TWO 10amp fuses on Slot #3
Or!
Using ATM Add-a-circuit with ONE 10amp fuse in any EMPTY Slots???
Old Dec 4, 2011 | 12:23 AM
  #158
kcle730's Avatar
Hey guyss, i found this Add-a-circuit at Autozone Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
would this work??? that way i won't have to cramp 3 in the same slot @_@
Old Dec 4, 2011 | 11:40 AM
  #159
SickFit's Avatar
Yes that part should work. It looks exactly as to the part that is described in the original thread that holds 2 fuses. Good luck on the project.
I don't have the GD3 anymore so I can't refer to the car anymore if you have any questions. I now have the GE8.
Old Jun 7, 2012 | 01:45 PM
  #160
FITdrummer13's Avatar
Worked great, perfect! Thanks for a great DIY took about 30 minutes tops
