KraftWerks Supercharger Kit Info v4.0
Old Dec 26, 2008 | 06:47 PM
  #141
usmc0341's Avatar
Originally Posted by eldaino
are they difficult to install? what kind of maintenence is required? what does it use to cool the tranny?
essentially it just mounts against the radiator...you just slip some zip-ties through the rows and there you go.
maintenance-wise it's just like changing your tranny oil during regular intervals. rule of thumb i think is every other oil change. as for what is uses, the tranny cooler is just like a radiator. you drive and it catches air while the tranny fluid flows through it.
if i provided any bad info, please correct me if i'm wrong...
Old Dec 28, 2008 | 11:49 AM
  #142
eldaino's Avatar
awesome, thanks for the clarification
Old Dec 28, 2008 | 12:44 PM
  #143
Wave's Avatar
That often on A/T fluid changes? Really? I was at around 75000 on the odometer when I had mine changed out. Maybe I'll do it more often now that the KraftWerks kit is installed but definitely not every other oil change.
Old Dec 28, 2008 | 03:29 PM
  #144
usmc0341's Avatar
you know i actually goofed on that one. i was thinking about rotating tires every other oil change, not tranny fluid. my mistake...
it should probably be changed every 40k miles, or 25k if you drive the fit hard. or make it easier on yourself and maybe do it every year.
i don't have the owner's manual handy, but does anyone remember what it says in regards to this?
Old Dec 30, 2008 | 12:18 AM
  #145
eldaino's Avatar
i'll have to check. there is a specific code on the maintenence minder that pops up and reminds you when to do it, and at almost 40k i've not seen it yet.
my fit sees about 85% highway miles, and when i got my car inspected, i had the honda tech tell me i should flush it out because it was 'discolored'. this dealer is known for ripping people off,so i just passed on his offer.
i agree about changing it more often after installing the charger...question is, would the maintenence minder call for it more often?
Old Dec 30, 2008 | 01:15 PM
  #146
OJRKraftWerks's Avatar
Former Vendor
The maintenance reminder in the car looks at your driving habits and mileage, and assumes the vehicle is stock.
-Oscar Jr.
Old Dec 30, 2008 | 02:49 PM
  #147
eldaino's Avatar
-Oscar Jr.
crap. so basically, i'll have to change it sooner.
Old Jan 7, 2009 | 12:07 PM
  #148
Former Vendor
It depends on your driving habits. Stop and Go traffic is hard on the transmission fluid.
-Oscar Jr.
Old Jan 7, 2009 | 12:10 PM
  #149
Wave's Avatar
Hey, how about that injector upgrade?
The AT kit is awesome so far.
Old Jan 7, 2009 | 07:36 PM
  #150
Fitftw's Avatar
did you get a dyno yet wave? or are you waiting for the injectors firsT?
Old Jan 7, 2009 | 07:59 PM
  #151
MNfit's Avatar
Im going to the local shop on the 27th to get the car dynoed and my Supercharger and Header installed
Old Jan 8, 2009 | 08:28 AM
  #152
Wave's Avatar
upgraded injectors first.
Old Jan 8, 2009 | 12:12 PM
  #153
Former Vendor
Yes sir. I have been sidetracked with internal projects, but we received injectors just before the holidays. Injector upgrade kits will be available shortly, I just have to get my act together.
-Oscar Jr.
Old Jan 8, 2009 | 01:24 PM
  #154
Wave's Avatar
Ready when you are boss! Are they just upgraded injectors or are there upgraded electronics with it too?
Old Jan 8, 2009 | 02:06 PM
  #155
eldaino's Avatar
in the vendor forum, oscar said that while there is no plans for a a/t highboost, a hondata MAY be in the works.
so we have base 5 psi, 5psi w/upgraded injectors and maybe 5psi upgraded injectors,hondata? (maybe the hondata version could at least up the boost without being called the 'high boost' as it would be less than 10 psi, maybe like 6-7?)
if the the upgraded injectors can get us close to 140whp that would be the nail in the coffin. my goal would be for at least 150 engine producing hp.
Old Jan 8, 2009 | 06:24 PM
  #156
Former Vendor
I wouldn't expect Hondata for Fit AT... The demand would have to go up tremendously. I just meant that it is possible... but not in the works. I should re-phrase my statement on that thread.
We have no plans for High-Boost Fit AT, Hondata Fit AT, or 09 Fit. The last two depend completely on demand.
Thanks,
Oscar Jr.
Old Jan 9, 2009 | 04:17 PM
  #157
MNfit's Avatar
Thanks,
Oscar Jr.
Thats a bit of a bummer to here, I may not have my kit on yet but im pretty sure down the road I will like to up the power of the SC. hopefully when that time comes there will be a high-boost kit or Hondata in the works.
Old Jan 9, 2009 | 04:58 PM
  #158
Fitcapo's Avatar
Thanks,
Oscar Jr.
That is a huge bummer and I don't think I don't know If I am going to save up for the kit anymore then
Was really looking to get base kit then getting the high boost once it came out but not anymore if there will be no hondata and highboost for auto
Old Jan 9, 2009 | 06:40 PM
  #159
Former Vendor
Guys,
This decision is based on automatic transmission safety of the Fit. Honda automatic transmissions are extremely finicky stock, and can only take so much when boosted. We have built our system so that its effect on the car is minimal.
So based on longevity and demand, we have chose to not release a High-Boost system for the AT. based on current demand, we have chose to not release a AT Hondata system.
I am sure AT kit owners can come on here and assure everyone that the AT Base kit is a great driving package, that really adds what the Fit AT needed.
-Oscar Jr.
Old Jan 9, 2009 | 11:08 PM
  #160
Wave's Avatar
-Oscar Jr.
Absolutely. The A/T Fit is a totally different animal with the KraftWerks kit installed. You can easily get into seriously illegal speeds very quickly with it and reliability has yet to be an issue for me. I'm NOT babying my car at all and I'm driving my Fit HARD. Taking off on other cars in the Fit's category is not a problem but don't go thinking you're gonna go off taking on Evo's and STi's on the road. Trust me, you'll surprise a fair share of drivers leaving them saying, "Why the hell can't I shake this guy?" I've done it....ALOT.
You guys might have noticed that I'm pushing hard for the upgraded injectors in my previous posts but quite frankly for most of your "real world" driving it's not really needed. But I am hooked on the boost and want to see for myself what that little bit extra can do.
The other choices for improving horsepower - turbo/engine swaps/the bottle, etc. all have their pro's and con's but in my honest opinion the KraftWerks kit is the choice that works for me.
Now if I could only match up the right lottery numbers so I can work on getting a new S2K with a KraftWerks HiBoost kit!!!
