2009 Accord horn on GE Fit
Old Feb 7, 2009 | 04:46 AM
  #101
lxwhite's Avatar
Just installed mine couple days ago... took like 5mins... very easy to do... sounds so much better...
Thanks!
Old Feb 18, 2009 | 06:27 PM
  #102
pinoyfitpilot's Avatar
Fedex just delivered and I did mine in 10 minutes. Easy mod. I cut one of the retaining clips on the shroud housing the hood latch, but with the new horn it fits snugly in place (minus the clip on that side). Just dont rush, read this thread, and take ur time.
Old Mar 16, 2009 | 09:41 PM
  #103
FireFox91's Avatar
I installed mine today. It was sooooo easy. Now I have a manly-man horn. Wile E. Coyote finally got that Roadrunner because the "meep-meep" is gone!
Old Mar 16, 2009 | 10:18 PM
  #104
Jspec5's Avatar
lol, wow i never thought it would get this big! i did it as a shot in the dark when i bought it and now look! everyone is doing it. im very pleased to see everyone has found this to be useful! next ill look into switching out the alarm horn cause it stil sounds the same. let u guys know soon as i find out!
Old Mar 30, 2009 | 02:15 AM
  #105
cool531's Avatar
I installed mine today. Very easy mod. Sounds much better.
Thanks for this thread.
Old Mar 30, 2009 | 06:14 AM
  #106
peg_leg's Avatar
Old Mar 30, 2009 | 08:01 AM
  #107
jrlnc's Avatar
Thumbs up I installed this last week!
This is a great mod, very easy and practical.
+1 rep!
Old Mar 30, 2009 | 09:11 PM
  #108
Benggolf's Avatar
Thumbs up Want your FiT to Sound Like A Suburban?
I recommend Fiamm El Grande electric horns....they are the greatest.
You can get them from Amazon.com for only $19.94!
Amazon.com: FIAMM 74100 El Grande - Twin Horns - Red: Your Store
I installed a set on my Yaris RS and wow! Guaranteed to get everyone's attention!
Old Apr 15, 2009 | 10:28 AM
  #109
Taffeta Fit's Avatar
Thumbs up
Originally Posted by Jspec5
I was tired of the stock weak horn on my GE8 but didnt want to opt for after market autozone crap (no offence to anyone here running that on they're fit) but i cant stand unsitely wires comin from the battery.
so heres what i did, i bought the OEM horn from the 2009 Honda Accord. now if you decide to do this know that the Accord uses 2 horns. a high pitch and a low pitch. BUY THE LOW PITCH.
install is exactly like the factory horn. physically they look different but hook up is the same. so no need to cut wires, run wires, hook up to the battery or nothing.
here is the part # 38100-STK-A02
Ordered mine today through a local dealer for $20.00, be here tomorrow! Thanks for the thread.
Old May 7, 2009 | 09:14 PM
  #110
natepartlan's Avatar
I had the local dealer honk an Accord, Odyssey, and Ridgeline/Pilot so I could pick the loudest one. Honestly I really couldn't tell much difference by ear so I went with the truck one figuring it was probably the loudest by some small degree.
The Ridgeline/Pilot low tone horn is pn 38100-s9V-A12 ($14.55 at my local dealer).
I didn't have to pull on the wire to get more slack and I had no interferences with anything on the car (just loosen the 10 mm bolt on the horn bracket and clock it around until you get the sweet spot you need).
Add me and my wife to the list of happy people no longer "meep-meeping" our way through traffic!
Old May 7, 2009 | 10:52 PM
  #111
ren hoek's Avatar
What's wrong with the stock horn?
Mine worked fine today when the "big pickup truck" driver cut right in front of me.
I've seen the vid and it does look kinda fun to do such an easy mod...
...maybe I should do it too.
I saw someone mention in a post they're investigating the alarm horn too...
...please post, I'd be interested to know more about that. Cheers.
Old May 7, 2009 | 11:42 PM
  #112
Litespeed's Avatar
For everyone having issues with wire harness slack, you can also reposition the black BRACKET the actual horn body is bolted onto - just loosen the 10mm nut on the bracket on the horn body and adjust as needed. It's torqued quite a bit and hard to get a good grip, so be careful.
Just don't angle to trumpet up (don't know if it's possible), you don't want water getting into it.
Also, as people have mentioned, the ALARM horn is under the driver's side (left) headlight assembly. If you have a SPORTS version, you can get to it by removing the fog light assembly and looking slightly upwards.
You can also access it through the engine bay with the right sized extensions/tools. It is visible though the engine bay without removing any covers.
Old May 14, 2009 | 10:20 PM
  #113
FIT_2a_T's Avatar
I did the horn mod a few weeks back, a simple, low cost and worth while upgrade.
Until I went to use my horn the other day and it sounded like someone had stuffed a bunch of socks in it. It made noise but no volume at all, just a muffled honk.
Checked my fuses, no problems there... I swapped the OEM horn back in (good thing I kept it) and it had no issues and it worked fine. I tried putting back in the Accord horn and still got the bundle of socks stuffed in it sound, grrr!
An Accord horn just gone bad?
Any one else have something like this?
Bernardi got it for me on 3/11/09, think they will send out a new one?
T
Old May 14, 2009 | 10:25 PM
  #114
bigmitch's Avatar
My horn is on it's way along with a few other goodies to put on the car. Always like easy mods.
Old May 15, 2009 | 01:51 AM
  #115
Benggolf's Avatar
Finally got my Fiamm El Grande electric horns installed.
They sure get a lot of attention, guaranteed to out do the Accord horn 10x!
Old Mar 19, 2010 | 08:04 PM
  #116
Irish4199's Avatar
Just installed the Accord horn!
Very happy with the results, and the install was pretty easy, even for someone with darn near no experience like myself.
Thank you again for posting this DIY!
Old Mar 19, 2010 | 08:56 PM
  #117
hogwylde's Avatar
Originally Posted by strmslvrfit
im interested in this mod, question: do you just replace the horn?? plug and play??
You have to download the "driver" too....
Old Mar 23, 2010 | 12:16 AM
  #118
citabria7's Avatar
Put mine one a few days ago, and believe it already saved my Fit from a big time crunch. Well worth the $20 buck and 10 minute install.
Old May 8, 2010 | 02:27 PM
  #119
shrique's Avatar
Horn upgrade
I thought I would toss this out there. I found a video from College Hills that goes through the whole upgrade process. In the video though they don't mention the actual type of horn they are putting in. Anyway it's helpful.
YouTube - Episode #156 - 2nd Generation Honda Fit Horn Upgrade
Old May 8, 2010 | 04:58 PM
  #120
VaMPKiSS1's Avatar
Just to help people that are having trouble finding slack in that wire, on my car I had the same issue. When I investigated I found out it wasn't because there was no slack, but because the wire harnesses were taped such that I couldn't get any when I tugged. So I took a little razor and cut the tape holding the two harnesses together, did my install, then taped the harnesses again. Solved!
I love the sound of this new horn.
