09 aftermarket wheels CAUTION
Old Jun 4, 2009 | 06:12 PM
  #361
MugenAP2's Avatar
Q) What do you think was the primary cause of the tire wear? Negative camber, or high pressures?
This is caused due to not having the car aligned after the camber bolts were installed most likely.
What is wearing out your tires is the toe!
My S2000 has 2.5 all the way around and I rag the shit out of the car and tires last about 8,000 to 10,000.
Old Jun 4, 2009 | 06:23 PM
  #362
blackvitzrs's Avatar
hey beng, I think you should be fine, but u're cutting it close. ppl have mounted 17 by 7.5 wih 42 or 43 offset with no rubbing problems. It also depends on the tires you're putting on. Some tires are wider and more reinforced than others even with the same spec.
You also have to consider the weight of the wheels. That is i think by far more important than rubbing, because you can always put in a camber kit. Do not put on wheels that are 19 pounds or heavier. Your fuel efficiency will suffer and so will your acceleration and braking. Acceleration when you are rolling will be noticeably compromised if your wheels are too heavy as our cars do not have the torgue for it.
A good thing is the stock 16s are quite heavy, so I think you should choose wheels that do not exceed the weight of the stockers.
Lastly, keep in mind that more mass that is at the perimeter of the wheel the harder it is to keep it spinning, ie the more power needed. More mass will be towards the perimeter of a 17" rim compared to a 15" tire, hence even if they weight the same, it will be harder to get the 17" rim rolling.
Old Jun 4, 2009 | 06:34 PM
  #363
Josephkao's Avatar
10000+ toe is off
Old Jun 4, 2009 | 09:44 PM
  #364
Benggolf's Avatar
Smile Thanks
Thank you Blackvitzrs for your detail explanation which is much appreciated.
I am toying with the idea of Gram Lights 17 x 7.5 (17.8 Lbs) with either a 205/40 x 17 or 205/45 x 17.
Given that the diameter of 205/40 x 17 is about .5" less than the OEM tires, it should help reduce the possibility of tire rubbing however, it will increase the fender-to-tire gap.
Tire Rack recommends 205/45 x 17 which is closest to overall diameter of the OEM tire and some guys in the forum have even installed 215/40 x 17.
Logically, 17 x 7 +43 offset Enkei RPF1 (weighing only 14.6 Lbs) is the wheel to get, but the design is a bit dated.
Ahh, decisions...decisions.
Old Jun 4, 2009 | 10:24 PM
  #365
AWDturbo's Avatar
Thx for the Feedback - One Last Question
Thanks for the feedback.
To be honest, I did get an alignment after I installed my springs last fall, but did not think that changing out the strut bolts would affect the toe, only the camber, so didn't go back for a new alignment.
I have to believe the my soft Blizzak's survived 3,000+ miles between November and March because I was driving on cold or frozen surfaces.
Consider this, too: I have a Taffeta White Fit, and I've wondered the past three months what the hell is up with this fine pitch black dust that's always on the lower sides and rear area of the car. It's not normal road grime/dust/dirt - and I now wonder if it's been my tires disintegrating.
So the question of the day is: if I stick with the wheels and try a set of P215/40's, do you think I'll be OK with the 2.50 degrees camber (and a professional alignment?) And when I take it to the alignment shop, would you advise I instruct them to set the camber even right & left, but to NOT set the camber to factory spec?
Thanks so much for helping me out.
Old Jun 18, 2009 | 12:22 AM
  #366
jericho941's Avatar
Will a TE37 17 x 7 +42 offset with 205/50 x r16 on my GE8....which is lowered with Tanabe DF210 springs rub?
Old Jun 18, 2009 | 02:49 AM
  #367
danielg's Avatar
if you're concerned about rubbing, roll your fenders
Old Jun 18, 2009 | 06:04 AM
  #368
cyergey's Avatar
Good luck getting a 16" tire on a 17" wheel. Did you intend to type 205/50/R17?
Old Jun 18, 2009 | 07:54 AM
  #369
mahout's Avatar
If you have an 09 with 205/50x17 tires on 42 mm offset and lowered I have doubts you will not have interference. I'm certain on an 08.
The 09 here didn't fit without rubbing on bumps.
Old Jun 29, 2009 | 01:31 PM
  #370
Tuned-R's Avatar
I have used 2 sets of rim for the GE8 being :-
1). AME Tracer 16"/7JJ/ 4 x 100/ offset 42
2). Dunlop Direzza 16"/7JJ/4 x 100/offset 43
Both rims use Dunlop RE001 205/50/16
Picture link :
Mods :: Fotopic.Net
My 3rd set will be RPF1 16"/7JJ/43
T-R
Old Jun 29, 2009 | 05:16 PM
  #371
mahout's Avatar
Originally Posted by Fitlurker
Can anyone confirm the 53 offset on the stock is true?
Yes, the stock 09 Fit wheel is 53 mm offset.
Old Nov 6, 2009 | 01:32 PM
  #372
chiman's Avatar
Wheel covers
Originally Posted by jeandeau
Interesting to see someone else out there who sees steel as practical. I mounted my 175-65 winter tires on a pair of saturn rims 14x5",57mmCB similar offset to stock. and a pair of geo storm rims 14x6" with 1" reduced offset. I hope I don't find a "Fit" problem with the fender come November.
I just bought a set of 15 inch Saturn's steel rims for my 09 Fit Sports. Do you think any 15 inch OEM Honda wheel covers will fit the Saturn's rims. Thanks.
Old Nov 6, 2009 | 11:59 PM
  #373
JDM-Taffeta-S's Avatar
I want your guys opinion im going for a flush look. im looking at a pair of 16x7 +33 offset and 16x8 +33 rear offset? will i rub too much or will this be the flush look i want. Does anyone have similar specs doesnt have to be staggerd please let me know. thanks
Old Nov 7, 2009 | 10:20 AM
  #374
mahout's Avatar
Since the minimum offset is 42 mm your 33 offset will rub like crazy unless you have really narrow and short tires.
Old Nov 7, 2009 | 11:24 AM
  #375
Spiritborn's Avatar
Will 17 x 7 with offset of 38 on 205/40/17 tires rub? I'm lowered on DF210's by the way. If it does not fit, is there a way to make it fit?
Old Nov 8, 2009 | 09:51 AM
  #376
ej96hatch's Avatar
Think I found some wheels that might work! I plan on either running some t1-r s coil lowering springs or an eibach pro kit! So the drop will be between 1.2-1.6 front and 1.4 in the rear! I want 17"s but if I have to settle for 16" i'm ok with that. The specs on the wheels are as follows: 17x7 +45mm or +48mm, 16x7 +45mm both wheels have a 75mm bore diameter. I was thinking about running 205/45/17 or 205/50/16! Could I run a wider tire then the ones I listed?
Thanks
Old Nov 8, 2009 | 05:16 PM
  #377
Marsbars's Avatar
So how bad will rubbing be on a stock height GE, with 18x8.5 +25 offset with 235-40-18? hahaha...
Old Nov 10, 2009 | 08:50 AM
  #378
Spiritborn's Avatar
I jumped the gun and had these rims installed. No rubbing at all, but then again I'm the only one riding the car. I use our CR-V when my family is with me.
ADR Propulsion. I got them rims and tires for just $475 via Craiglist and they're brand new. Former owner had to get rid of it 'cause he sold his Civic and bought a BMW.
Old Nov 10, 2009 | 08:49 PM
  #379
YJWAVE's Avatar
Originally Posted by EK3 Ferio
Confirmed!
17x7 +43 w/ 215/40/17 tires lowered = no rubbing at all!
Does this mess with your MPG at all?
Old Nov 11, 2009 | 07:39 AM
  #380
alex1204's Avatar
how many is the Center Bore diameter of jazz 2009?
