Instriment panel foggy
Hello, I'm new here. I've had my Fit for just over a year and I love it, no major problems in the 62000 miles I've put on it (I drive alot). One issue that I encountered is that the see through plastic for the gauges (speedometer, rpms, etc) have clouded up, from the inside. Does anyone know a simple solution to fix this, it's not that big of a big deal and I'm not going to take the dashboard apart to fix it, but I was wondering if maybe there is an easy fix.
I'D bet the windshield was replaced and not sealed properly, water is getting in/under the dash and with the heat is fogging up - sorry to hear, it might take a bit more effort to get that fixed, i'm sure a hair dryer will heat it up enough to make it go away but if you don't find the cause, i'm afraid you'll get it back
my .02
my .02
BluesSlinger
12-20-2010 04:36 PM
