'Mythelogy' lightened crank pulley
Old Nov 28, 2007 | 09:59 AM
  #161
gettinafit's Avatar
Originally Posted by SPON FIT
sweetness thanks man
Regular threaded, You will need PB Blast let it soak! DO NOT TAKE OFF THE DRIVE BELT AT FIRST!! Loosen the Crank bolt first!!
Probably have to use an air impact gun! Or somehow hold the pulley from moving while you loosen.
Old Nov 28, 2007 | 10:32 AM
  #162
SPON FIT's Avatar
i have an impact so it should be a simple install.thanks for the advice
Old Dec 26, 2007 | 08:33 AM
  #163
nttdemented's Avatar
Whats the final word on the Myth pulley? Does the dampening it have work or not? I honestly understand that tech article that was posted a few pages back and I don't want to eliminate the harmonic damper, I've seen different materials crack when they resonate against their natural frequency and I have also known cars that have gotten long term damage from pulleys. So whats the word?
Old Dec 26, 2007 | 08:41 AM
  #164
kimo's Avatar
I have Summit pulley for almost a year now and it works fine, so just go ahead.
Old Dec 26, 2007 | 09:44 AM
  #165
claymore's Avatar
Once again the stock Jazz/Fit pulley does NOT have any harmonic damping AT ALL you could run the engine with NO PULLEY. IT'S JUST A PULLEY.
Old Dec 26, 2007 | 10:07 AM
  #166
kimo's Avatar
I total agree with you
Old Dec 26, 2007 | 12:59 PM
  #167
Jimmy101's Avatar
I have 15k miles on my summit pulley with no problems.
And I have no extra vibrations, I use a gatorback belt,
that prevents belt slippage, so by gentlely tightening
the belt, you prevent NVH from the belt & pulley
Old Jan 25, 2008 | 02:13 AM
  #168
xorbe's Avatar
where do we get our hot mitts on these things? thanks! there's no place to click on the main web page. or is it better to go with the unorthodox version. or summit.
Old Jan 25, 2008 | 04:09 PM
  #169
tricolor's Avatar
But... what did you not like about your Mythelogy to make you switch to the Summit?
Old Jan 25, 2008 | 11:38 PM
  #170
Jimmy101's Avatar
The weight. saved about 6oz.
Old Jan 26, 2008 | 02:40 PM
  #171
xorbe's Avatar
where can the Summit pulley for Fit be purchased?
Old Jan 28, 2008 | 04:32 PM
  #172
Jimmy101's Avatar
Here's the us distributor, looks like they redsigned the pulley.
I have no idea how much it weighs.
GTSPEC
Old Jan 28, 2008 | 05:16 PM
  #173
Zangoose GD3 Blue's Avatar
GTSPEC
do i have to call them to place an order...
Old Jan 28, 2008 | 05:20 PM
  #174
Jimmy101's Avatar
call them, AJ-Racing also sells this pulley!
Old Jan 29, 2008 | 10:45 AM
  #175
jazzista's Avatar
Hi claymore, all,
sorry for dumbness. Is it correct to suppose that even my 1.2 DSi won't have a harmonic dampener on its stock pulley? I plan to check with my eyes anyway...
Stefano
Old Feb 3, 2008 | 07:34 PM
  #176
kimo's Avatar
Yes, and you can install this pulley in your car.
Originally Posted by jazzista
Hi claymore, all,
Stefano
Old Feb 4, 2008 | 11:24 AM
  #177
jazzista's Avatar
Thank you a lot,
Stefano
Old Feb 4, 2008 | 04:21 PM
  #178
Sugarphreak's Avatar
Push My Button
That is good to know, I was hoping the T1R would be ready but I havn't heard anything about it for a while. Maybe I will go with this one instead
Anybody have comparison notes between this pulley and the UR set (disregarding the Alt pulley)? Any advantages or disadvantages other than weight... or basically the same product?
Old Apr 11, 2008 | 07:14 AM
  #179
smirff07's Avatar
anyone recomend a good belt for reasonable price?
Old Apr 11, 2008 | 06:49 PM
  #180
Jimmy101's Avatar
Get the Gatorback belt from autozone, its cheap. prevents slipping and don't overtighten it! It only needs to be mildly tight, so you get no increase in NVH with the aftermarket pulley.
Kate Ginsburg
Jul 29, 2015 08:28 AM
