Pros and Cons of KWSC vs T1R Turbo
Old Jun 23, 2008 | 08:35 PM
Originally Posted by leonine
how's your kit running otherwise. any dyno results?
i have an appointment for dyno time on thursday. after i put the kit in, i was getting some minor pinging from the engine but after i threw five gallons of some 104 unleaded, all the pinging went away and my car is running perfectly. it feels very very fast. i cant wait to see my numbers.
Old Jun 23, 2008 | 08:38 PM
Originally Posted by eldaino
but the kwsc is going to give you the feel of a bigger engine, which is going to be more seamless in power delivery and thus better for what seems to be your needs.
no disrespect intended but maybe these claims will be true with the hondata and the 8-10psi upgrade(it looks so from jdmchris's vid) but not with the base kit. and with the 8-10psi and hondata you are looking at least 5 grand. better to do a k-swap for that kind of dough imo.
Old Jun 23, 2008 | 08:40 PM
cool beans. post them up please. now you are just running 91-93 octane right? maybe was from running 87 octane since you owned the car?
Old Jun 23, 2008 | 08:44 PM
actually ive ran my car on 91 octane since ive had it. the gas i had in my tank was 91 but it had been sitting in 90 degree weather in the daytime and 50 degree weather at night for two weeks straight just sitting there. so im guessing the expansion and contraction of the gas could have lowered the octane a few points. i had like a quarter tank in my car of the old 91 so i put 5 gallons of the 104. still havent gone through the 104 because i just put it in today
Old Jun 23, 2008 | 09:14 PM
underdog's Avatar
the which is better debate can go on and on. it's mostly a matter of preference. like stated the kwsc is going to give linear power delivery but you sacrifice power under the curve as apposed to turbocharging. the turbo will come on a little slower on the 3k below rpms but pick up like crazy all the way to redline.
both with safe tunes should be fairly reliable. obviously there can always be driver error which will be blamed on the manufactuer. lugging the engine is typically what kills most boosted cars. and basically that is where your loading the engine very hard like if you were cruizing at 35mph in 4th and you just punch it rather than down shifting. and also 5 gear pulls on the highway with long sustained loads can also cause major problems. another thing is getting a bad batch, or fuel or since gas is so pricy maybe i'll just run low grade for now. then that unsuspecting type R pulls up and you decide to race them on a 115' day. and well you get the picture.
both systems with moderate boost, good fuel and common sense should be plenty safe to daily drive and take road trips as long as the precautions are made.
Old Jun 24, 2008 | 06:39 PM
we don't really know what the hondata/8-10psi kits are going to cost. and 5k only buy's you a an actual k series engine.
i'm sure the upped boost will make MORE power obviously, but the linearity of it and the impressions that it gives on any level should be consistant from kit to kit.
Old Jun 24, 2008 | 07:24 PM
yeah especially when your adding another 1k for the k pro. another 1 k for the mounts,axles and misc stuff.
it would have cost me 7k for all the stuff i wanted.
yeah it will boast near 200whp for the things i needed. but is it really worth HALF the price of what my car is worth. not really. ill save the 2k and invest it into something else
Old Jun 24, 2008 | 07:25 PM
god im torn, kw or t1r...ewww
5k is around my budget.
Old Jun 24, 2008 | 07:54 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
they're both sick
but IRL, if i had to choose
for DD purposes, i'd chose the KWSC
but that's just me
Old Jun 24, 2008 | 08:05 PM
zRollerskate's Avatar
id go turbo cuz ive always wanted a turbo car... ive driven supercharged muscle car and i know they are ungodly... but this, ladies and gentlemen, is no muscle car... but id still turbo the shit out of it =D
Old Jun 24, 2008 | 08:12 PM
true that true that
Old Jun 24, 2008 | 08:17 PM
Sid 6.7's Avatar
Why so serious?
For me, I'm planning on doing a K20 swap. A turbo or s/c for $6000+ to have 150whp?
Goodness, I can have a nice K20 swap for $4k and have a cool 200whp all motor. Then if I just wanted to spend that extra $2k, I could do some head/cam/tuning and have 240whp or more.
Old Jun 24, 2008 | 08:19 PM
man parts and motors must be cheap for you!!!!
shit 5k for us over here gets the motor.
if i could get a k20 swap for 4k i would be all over it right now.
without any doubt
Old Jun 24, 2008 | 08:24 PM
i really just wish honda would have made the sport edition cost more and come with an engine like a K20
Old Jun 24, 2008 | 08:31 PM
YeeFit's Avatar
I don't know either how you can do a K20 swap for 4k. And in no way is the KWSC kit 6k.
I can get a K20 motor w/tranny in town here for 6k, + Kpro ($1000), + mounts, axles, etc ($1000), + installation and tuning = 9-11k.
A KWSC kit (highboost) when it comes out will (hopefully) be under 5k. And you will be getting around 170hp and 150-160 torque to the wheels...
KWSC is direct bolt on with hondata programming. K20 is custom installation with some cutting and modifications to get it in... that = big $$
Old Jun 24, 2008 | 09:28 PM
Sid 6.7's Avatar
Why so serious?
Wow, I guess there could be a higher cost involved depending on engine availability and where you're getting it.
I got a RSX Type S 210hp engine I can get for about $1800 for engine/tranny/axles and whatnot. Swap, tuning, ECU and labor were going to run me a little bit, but last time I added this up, which was last year when I first got the Fit, I figured up about $6k.
I guess depending on which exact engine you get and where you get it could run the price up huge.
Old Jun 24, 2008 | 09:32 PM
http://www.hmotorsonline.com/shop/sc...age&item=30015
for that type s motor you were talking about.
http://www.hmotorsonline.com/shop/sc...age&item=30014
the one i would like to buy
and i would go pick it up myself of course to save money on shipping.
but just that alone is near what you estimated all together. i need to do the swap somewhere else in the us.(your area) because you get stuff for dirty cheap.
Old Jun 24, 2008 | 09:36 PM
Sid 6.7's Avatar
Why so serious?
Wow, that is high dollar!
Old Jun 24, 2008 | 09:38 PM
your telling me man. but most people down here buy from them. they are legit and i havnt seen an engine fail yet.
