The saga continues... 2007 Fit 120K miles.
Old Sep 22, 2019 | 05:29 PM
Herb Kutscha's Avatar
Misfires, loss of power. I did the plugs and coils, with some improvement.
I found out about the ECU training procedure, and it helped quite a bit after the change. I believe that this ECU procedure should be done every time you ECU loses power - battery changes, disconnecting the battery, etc., Or "fixing" something
My car actually prompts during the procedure, counting down the time. If you don't do it, an ECU reset can mess up timing, etc., and the ECU will take it's time trying things based on it's current data
Anyhow, I'm still having problems. Lots of miles, and I haven't done the valve adjustment, which probable should be next.
But are there sensors to work on that could be causing the problem? And should I be worrying about the fuel filter? What are the symptoms of a clogged fuel filter? I'm still getting lots of power at full throttle. What should I do next?
Old Sep 24, 2019 | 03:13 PM
Jared592's Avatar
Get the valves adjusted first.
Old Sep 24, 2019 | 11:45 PM
doctor J's Avatar
Re-check your plug/coils job
I have a feeling that you got counterfeit coils (unless you bought them from official Hitachi distributor)
Old Sep 25, 2019 | 10:26 AM
Jared592's Avatar
Good point J, there are tons of cheap junk coils out there. If you didn't go with OEM or Hitachis (the same thing except OEMs are marked up), definitely fix that first.
Here's what you want (buy 4):
Amazon Amazon
lakia5524
Oct 3, 2012 01:18 PM
Trainman
Jul 19, 2012 12:56 PM
jenos
May 20, 2011 10:48 AM
DOHCtor
61
May 2, 2011 05:18 PM
buttersandpaper
Feb 15, 2011 11:22 AM
