Bad noise in engine (video included)
Old Oct 5, 2019 | 08:38 PM
tremblorfit07's Avatar
Hey guys. I did my valve lash like I mentioned. Before the adjustment the engine would idle quiet but under load would generate a fast knock/tic until it was warm then it went away.
After the adjustment its quiet at idle when cold, then loud knock/tick under load cold and warm, and now knocks like this at idle once warmed up.
https://youtu.be/Exs_hYoYnNA (link to video of sound)
Thanks.
Old Oct 5, 2019 | 10:08 PM
Baldwin Nguyen's Avatar
Thanks.
Is it throwing any CEL?
Old Oct 5, 2019 | 10:32 PM
Hey, it's not throwing any codes. Runs good. Seems a bit gutless in the top end.
Old Oct 7, 2019 | 12:09 AM
CamperCarl's Avatar
I'd start with getting a valve adjustment. Common problem with our engines.
Old Oct 7, 2019 | 11:24 AM
doctor J's Avatar
Thanks for posting the video!
Use a search function (NOT to be a self-advertiser):
https://www.fitfreak.net/forums/1st-...e-located.html
Use long screwdriver otr mechanics stethoscope
If noise is loudest at the areas mentioned in the thread
It has nothing to do with the valves.
It's a piston slap!
Old Oct 7, 2019 | 01:24 PM
It's a piston slap!
Yeah, its gotta be piston slap. Doesnt seem to burn oil, is it fine to run?
Wierd part is that its queit at cold start, after warming up completely it knocks at idle? Usually piston slap is the opposite?
Old Oct 7, 2019 | 05:54 PM
doctor J's Avatar
On older cars with cast iron engine it acted differently. On my car it's most audible with warm engine between 35 and 70 degrees C. No, the engine will not blow up or blow by (pardon the pun)
Old Oct 7, 2019 | 07:19 PM
petelite's Avatar
Sounds exactly like mine, at this point I'm just ignoring it. Mine doesn't slap when cold, and doesn't slap when fully warmed up - only between the two. 240k miles and still going.
Old Oct 10, 2019 | 04:23 PM
ConnorBe's Avatar
Good ol' piston slap. Mine will start after the cold light turns off and usually goes away after 30 mins ish of driving on the highway... it's the only thing i don't like about the car.
Old Oct 11, 2019 | 05:08 PM
Yeah, mine is identical. It idles quiet as a mouse when cold, but after running it awhile the idle will knock. Light throttle on flat ground produces no sound, but as I push the throttle it begins to knock really loud. Once super warm it still knocks under load but quieter... it definitely gives me an uneasy feeling.
Old Oct 13, 2019 | 06:16 PM
doctor J's Avatar
The drawback of this is later than normal ignition timing at acceleration (knock sensor picks piston slap as spark knock); if you push gas more, transmission will downshift (this explains declining fuel economy)
Old Feb 3, 2020 | 12:31 PM
petelite's Avatar
Well, I had an oil analysis done on my tapping 2008 Fit sport, and all looks fine!
Old Feb 4, 2020 | 10:33 AM
doctor J's Avatar
What is the brand of oil filter?
valve tick or piston slap will not add wear particles, unless it's progressing.
many loud engines tend to run for long time
Old Feb 4, 2020 | 12:06 PM
petelite's Avatar
It's a Royal Purple filter. Yes, just some additional reassurance that it is indeed piston slap and not rod knock.
ommegga
Feb 14, 2020 12:21 PM
danielmorrison
Jan 26, 2018 09:47 AM
RandomKoko
Jun 29, 2017 09:10 AM
Fitguy07
Jun 24, 2014 09:14 PM
qbmurderer13
Feb 17, 2010 10:53 PM
