New noise and feeling
Old Nov 9, 2022 | 10:03 PM
suprman182's Avatar
Hello I have a 2008 manual transmission Honda fit. It has about 125,000 miles. When I was driving today to work I started to hear rotating clunck sound. It coincides with the rotation of the wheels. As I'm driving I can feel and hear the rotating click coming from the left front wheel or the axel of the front wheels. Has anyone experienced this and know what it is and how to diagnose and fix it. I would consider myself an amateur mechanic. I can do some hard things if I'm able to look it up on YouTube and I see a visual and how to do it. Any help would be appreciated.
Old Nov 12, 2022 | 04:25 PM
doctor J's Avatar
Check the axle fro rust damage; there is recall to replace axles if car has been in salt belt free of charge
Old Dec 27, 2022 | 08:30 PM
mifesto's Avatar
also check brake dust shield, thats a common one that will cause grinding noise. either the shield is touching the rotors or a rock got caught between in.
hopefully its not your wheel bearings
Old Dec 29, 2022 | 04:54 AM
hugojose's Avatar
........I presume rotation of wheel is rotation and not turning. Could it simply be brake pads getting worn out?? Not sure on the Fit, but many pads have wear tabs rubbing to 'scream',,,,,,,, replace me!
Christina Diaz
Mar 20, 2018 03:10 PM
salamlaith
Aug 24, 2016 08:55 AM
tomsandoval
Jul 23, 2016 11:55 AM
MagicGuitar
Oct 13, 2015 05:14 PM
tin
Feb 14, 2008 03:17 PM
