Rim size Fit 2007
Old Jun 1, 2023 | 04:13 AM
georgi6's Avatar
Rim size Fit 2007
Hello there,
I tried to find the original rim size for Fit 2007 base.
In my book didn't locate in which chapter are the rims, not in specs, not in suspension, or steering.
Online from vendors found different sizes:
14 X6 4-100.00/114.30 38
(14 x 5.5 inches /4 x 100 mm, 38 mm Offset)
5.5Jx14 ET45
It's frustrating.
Old Jun 1, 2023 | 01:36 PM
Damian Clement's Avatar
Have you tried looking at https://www.wheel-size.com?
Old Jun 2, 2023 | 10:09 AM
mykizism's Avatar
Originally Posted by georgi6
Hello there,
5.5Jx14 ET45
It's frustrating.
The most likely reason you find two different specs is because one size 14x5.5 is for the steel wheel and 14x6 is for the alloy wheel.
Old Jul 26, 2023 | 05:37 PM
Mgflofit's Avatar
May be a little too late... But I put on GE8 stock 16" wheels and tires on my GD3 without any issues. The only thing is that the stock tires are a bit tall so the speedometer is underestimating the speed which hasn't been an issue.
Old Jul 31, 2023 | 01:18 AM
mykizism's Avatar
Your speedometer is reading accurately according the rotations of the speed sensor located inside the transmission. However.. your actual speed may vary. I've seen a few GE8 fits with GD3 Fit alloy wheels.. You should be fine.
Old Aug 6, 2023 | 06:27 PM
Mgflofit's Avatar
Whoops, that's what I meant. My "actual" speed is about 3-4 mph faster, if i recall with my taller tire size. Thanks
Old Aug 11, 2023 | 01:11 AM
Silver GD3's Avatar
The steel wheel is 14 x 5, and the tire size is 175/65 14. That was on the base model, 2007. The alloy wheel is 15 x 6, with an offset of 55. The tires is 195/55 15. This is on the 2007 sport model.
Old Aug 11, 2023 | 01:18 AM
Silver GD3's Avatar
If you run 195/50 16 tires on the GE8 wheels, that would give you a more accurate reading on the speedometer. Because on the GD3, they also had HFP wheels that were 16 x 7. Those wheels went with 205/45 16, on the GD3 vehicle. If the GE8 wheels are 16 x 7, then run the 205/45 tires. If they are 16 x 6, then run the 195/50 tires. Hope this helps.
fitter_happier
May 27, 2011 03:41 AM
smellslikeFIT
Apr 6, 2011 07:34 AM
Halcyon
Nov 25, 2010 07:15 PM
die_lawn
Nov 5, 2009 11:33 AM
