Best tires for 17" shoes?
Old Jun 23, 2009 | 09:00 PM
Type 100's Avatar
Hmmm. Isn't an 8"-wide rim a little too thick?
Old Jun 23, 2009 | 09:10 PM
mahout's Avatar
Originally Posted by Black01
Is 17x8 4 x 100 +48 offset gonna fit without problems in the GD3?
The wheel offset is good but the dish needs to checked for the centerbore and clearance around the calipers/drums.
And then the clearance around the rim on suspension parts.
And whether it fits depends mostly on the tire selected.
If you select 17x205/40 or 195/40x17you may be OK. But then the wheel is way overkill.
Old Jun 23, 2009 | 10:38 PM
Black01's Avatar
That's what I'm thinking about too. It may be a little wide. Maybe I should try 17x7.5 4x100 with offset +45. I'm thinking of using 205/40R17 tires on it. I have not decided yet which wheel because its hard to choose because all the 3 choices I mentioned all looks great.
Old Jun 24, 2009 | 12:15 AM
Type 100's Avatar
Erratum:
205/40R17 was indeed the tire size recommended on our shores, not 215. Apologies
Old Jun 24, 2009 | 10:27 AM
mahout's Avatar
Any width over 7" is overkill and probably costly and poorer performing unless you find a really light 17x7 wheel.
The best overall tire is Yokohama S Drive 145/40x17's. Winner all the way around on 45 mm offset, even 42mm but not less.
Old Jul 12, 2009 | 11:56 AM
Black01's Avatar
I found this guy running the same size of the wheels that I want and he said that the only problem he had was the front wheel well cover was rubbing. And he did tucked the cover and no more rubbing. I' not sure if this info will be 100% sure because he is the only one I saw rocking this size of wheels and tires. His wheels looks good so I chopped it on an MR Fit
Click Here to see his thread
Stock Look(original picture)
Stock Height with 17"s
Last edited by Black01; Jul 12, 2009 at 12:28 PM. Reason: Pictures are not showing and added link to the thread.
Old Jul 12, 2009 | 12:06 PM
Black01's Avatar
Lowered the Fit with the same 17"s
Last edited by Black01; Jul 12, 2009 at 12:26 PM. Reason: Somehow pictures do not show.
Old Jul 12, 2009 | 12:29 PM
Black01's Avatar
I'm sorry for editing my post too much, I had to go to imageshack to host my pics. Webshots grrr....
Old Jul 12, 2009 | 03:48 PM
Necos07's Avatar
Check out this offset calculator link its helped me out alot Wheel Offset Calculator
205/40/17 is a great size but you need to concentrate on the offset unless you want problems. I had 17x7 with 40 offset and with stock height I rubbed front and back on every little bump.
Old Jul 12, 2009 | 04:01 PM
Black01's Avatar
thanks Necos07, your comment helps a lot.
FIT-tles Worth
Jul 13, 2012 02:34 PM
JDM-Taffeta-S
19
Oct 4, 2011 06:15 PM
AugeesFit
Sep 7, 2011 06:00 PM
greekdaddy000
May 28, 2010 12:19 PM
robfit
Sep 16, 2007 01:33 AM
