Had my 07 GD for a week so far...couple of questions / concerns
Old Jul 25, 2009 | 10:55 PM
kimdizzle's Avatar
So I've had my Fit since last Friday...
1) The temperature light comes on pretty much every time I start up the car and stays on for a minute or two. Is this normal?
2) I don't think it's my driving, but every time I go from a stop, I barely push the accelerator, but I feel like I'm flooring it...
3) The ride is bumpier than I anticipated. What's the cheapest ways to make this better?
Thanks in advance.
-kimdizzle
Old Jul 25, 2009 | 10:58 PM
Jodele's Avatar
-kimdizzle
No..this is not normal!
Old Jul 25, 2009 | 11:39 PM
polaski's Avatar
1) green cold light when coolant is less than 125 deg F, red hot light when it's overheating. It replaces the coolant gauge that I'd rather have there. If the cold light DOESN'T come on the first time you start it in a day, you have a real problem.
2) yeah the pedal is super-sensitive on tip-in compared to most cars. I added an extra spring to mine, DIY in the DIY section.
3) low-profile tires. Only way to improve is change to the base's tire size and steel rims/hubcaps.
Old Jul 26, 2009 | 06:19 PM
MNfit's Avatar
low-pro tires would make the car bouncier and a much harsher ride. The car is a short wheel base so it is affected more by changes in the road and there is not much you can do
Old Jul 26, 2009 | 06:24 PM
trancedsailor's Avatar
add coilovers and attack those bumps
Old Jul 26, 2009 | 07:54 PM
dewthedew's Avatar
my cold engine light comes on everytime i first get in the car and stays on for a few seconds.
Old Jul 26, 2009 | 08:24 PM
mahout's Avatar
[quote=kimdizzle;706534]So I've had my Fit since last Friday...
Absolutely. As long as the coolant temperature is less than the programmed lower limit or above the upper limit the light will come on. As soon ass temperature is in spec light will go out as it should.
For some reason the electric control throttle appears to get up and go quicker than most of are used to. Probably due to the required initiation resistance to get it up and measuring. You will get used to it. After of course initiating a few unintended 'drag' races at stoplights. (which you will lose).
Its a lightweight car so the shocks will be 'bumpier' than a Chevy SS. You could substitute softer shocks but you'd bump stop every other bump in the road.
Old Jul 26, 2009 | 08:50 PM
Type 100's Avatar
Agreed.
Lowering springs and a few coilover sets do help tame the ride though.
Old Jul 26, 2009 | 08:52 PM
Fitftw's Avatar
i heard endura-tech coilovers are the way to go for comfort improvement in suspension
Old Jul 26, 2009 | 08:56 PM
Cat's Avatar
Cat
Welcome to Fit ownership and all your concerns are perfectly normal for the car. The temp light will always be on until the engine warms up which is normally just a few minutes of driving. Check your tire pressure 32 PSI or slightly over will make a big difference.
Cat :x
Old Jul 26, 2009 | 09:10 PM
Black01's Avatar
Thanks in advance.
-kimdizzle
I know your questions have been answered but again "YES" these are normal.
Old Jul 26, 2009 | 10:25 PM
Necos07's Avatar
Hey check the tire pressure for the bumpy ride problem your having. When they ship cars they set the pressure high as heck up to like 45-50 psi and the dealer is supposed to adjust the pressure when the car is delivered but they might have missed yours.
Old Jul 26, 2009 | 10:53 PM
Type 100's Avatar
TEIN Super Compacts too if you can score a set. They ride beautifully but can also firm up for more aggressive driving.
Old Jul 27, 2009 | 03:40 PM
Fit4Pits's Avatar
Her car did not come from a dealer.
(disclaimer: assuming OP is a girl, kim)
Old Jul 28, 2009 | 12:45 PM
Juliane's Avatar
So here's another "Yes your car is normal" answer!
The Cold light comes on even if the outside temperature is 100 degrees. It only stays on a minute or two in hot weather, but will stay on longer once the winter comes.
You will have to compensate for the jumpiness of the accelerator. Myself, I enjoy jumping off the line and beating whatever car I'm sitting next to! They always look surprised and dismayed.
This is a Honda! Road noise and a harsh ride are a given, unless you are in an Odyssey, and even then, it still has the noise, just not so harsh.
You didn't mention dash rattles, which I would expect since you bought a used car. Another little annoyance you can't do much about, except turn up the stereo!
Old Jul 29, 2009 | 10:22 PM
Thinkfit's Avatar
1. I've had mine for about a month now and the temperature light still come on when i first turn it on for the day.
2.
i felt the same way when i first got it. it surprise the hell out of me
3. no advice it feels fine for me
Old Jul 29, 2009 | 11:46 PM
Texas Coyote's Avatar
Check out Polaski's throttle spring fix it is a simple way to add resistance to the pedal so you aren't always driving while trying to keep your foot from resting too heavily on it.... There are a bunch of us that have done it and it is something I wish that I had thought of and done when I got my car three years ago. Lighter wheels and performance touring tires like Conti Pro Contacts are the best thing that I did for my car's ride, handling, braking, fuel mileage and accelleration.... Of course I did get even better acceleration with a super charger.
Old Jul 30, 2009 | 12:55 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
slam that bitch on coilovers to fix your problem
:thumbup:
lschiffer
Jun 3, 2023 01:07 PM
Browny1512
Jan 3, 2016 02:57 PM
chachski90
Sep 11, 2013 09:59 PM
barams
Oct 4, 2008 04:31 PM
Lalala218
Jun 11, 2006 02:29 PM
