PLEASE HELP! Header install question
Old Sep 8, 2009 | 09:44 PM
Burbio's Avatar
Originally Posted by kylerwho
what you have to do is drive around until the car gets hot. then park it and wait until the engine is cold and re-check all the bolts and nuts. the header will expand before it settles and thus the weird noises.
I've put about 400-500 miles on it since I installed it, including a 220 mile drive from San Diego to Santa Barbara. I checked it today and retightened everything, because the header HAD settled a bit. But since I re-tightened everything, the noise seems to have gotten worse.
Old Sep 8, 2009 | 09:46 PM
kylerwho's Avatar
spoon fed
did you put a new gasket on too? the oem gaskets are crushable design and are not meant to be used over and over but you can do that cause its cheap and they hold together.
Old Sep 8, 2009 | 10:02 PM
Burbio's Avatar
Yeah, I put on a new gasket. I guess I'll just give it time and see if it stops?
Old Sep 8, 2009 | 10:07 PM
Mr08FiT's Avatar
maybe it's hitting that hanger the stock header mounts to behind the block? Or it's the b-pipe and it's been pushed back some? just thinking outloud here... Also can you feel the "clunking" through the brake pedal? or the steering wheel? maybe the floor?
suketoborudo00
Sep 27, 2014 07:48 PM
Lyon[Nightroad]
Jul 16, 2014 08:58 PM
IIEZ
39
Jan 19, 2011 10:25 AM
kevinkidstar138
Feb 25, 2010 05:17 PM
kifu
Oct 26, 2007 02:45 AM
