Required major maintenance 80k so far..
Old Apr 28, 2010 | 02:43 PM
Previc93's Avatar
Originally Posted by kakrohn
Don't EVER do fuel system cleaner UNLESS you are experiencing symptoms. Using these can cause chunks of carbon deposits to break off & clog your system... then you'll have to pay them big bucks for repairs.
this only happens if you dont do it regularly. if you wait 100 k to do it then ya you'll have a bunch of carbon build up and fuel injectors could get clogged.
Old Apr 28, 2010 | 03:06 PM
kakrohn's Avatar
To me, major would be something not included in the normal Maintenance Minder Chart for our cars.
Old Apr 28, 2010 | 03:10 PM
kakrohn's Avatar
yeah
That is true, for the most part, but there's still a chance.
Also, buying the cheap Auto Zone cleaners do nothing that today's gas doesn't do already. Just like oil, gas has come a long way since 1990. They are all mandated by the govt to put cleaning additives in.
Old Apr 28, 2010 | 03:11 PM
AnlDyxp_GD3's Avatar
Originally Posted by Fieldstone
I'm not sure how you'd define major.
I guess anything thats not just an oil change. lol.
Old Apr 29, 2010 | 12:59 PM
CuTeBoi's Avatar
I follow the mantra, if it ain't broke, don't fix it...
I don't believe in this mantra, cause you don't know it's broke until it's already broken... I rather do preventative maintenance, than nothing at all and find out I destroyed my car, and insurance doesn't cover it.
but I check my fluids every couple of weeks to make sure they are still clean and fresh.
I do this, but that's about all I do.....
Took the car to get brakes checked, haven't changed them in 60k miles... and they are good. Shows how much braking I actually do... scary thought.
I'll try and get the chance to do the valve spacing checks done soon...
Old Apr 29, 2010 | 01:08 PM
JDMxGE8's Avatar
Major maintenance in my book consists of:
Adjust valves
Check brakes
Check suspension components
Check tire pressures
Check/top off all other fluids
Clean injectors
Flush coolant
Oil/filter change
Replace fuel filter
Replace spark plugs
Replace transmission fluid filter
Tire rotation
Transmission fluid change
Wheel alignment
Wheel balancing
That's all I can think of off the top of my head. I know I probably forgot some stuff.
Old Apr 29, 2010 | 01:11 PM
Selden's Avatar
Did you get the brake fluid flushed? After 60K miles, it must be the color of strong tea. I try never to go more than 24 months between complete flush and replacement of brake fluid, which becomes contaminated with moisture over time.
Old May 1, 2010 | 04:09 PM
Fieldstone's Avatar
I've never done any brake fluid changes. Does Honda recommend it? My mm never prompted me.
Old May 1, 2010 | 06:51 PM
CuTeBoi's Avatar
What color SHOULD it be? or is the tea color of Earl Grey tea a good color? opening the container holding the fluid exposes it to moisture, so I don't think checking that fluid except through the container sides is advisable, no?
Old May 1, 2010 | 07:57 PM
Selden's Avatar
Clear is great; straw is OK; Lipton is bad. Most people don't bother with proper changes of brake fluid on a car because it's such a pain. A tool such as a MityVac makes the job a lot easier for one person.
Old May 1, 2010 | 08:50 PM
jondotcom's Avatar
3yrs is the interval I'm pretty sure.. it is in the manual though.
Old May 2, 2010 | 06:44 PM
  #32
Jimmy101's Avatar
I'm pretty much in the same boat. I have 98,000 on mine.
I've done:
oil (every 6k miles or so)
air filter changes (when dirty)
transmission drain and refill @ 80k
Tires @ 50k
Front Pads @ 70k, rears still ok per mechanic.
pressure switch in tranny had to be replaced 2 weeks ago.
It's a pretty low maint. car. All cars should be this easy really.
Can you tell us what symptoms did your transmission have that it needed a new pressure switch?
Old May 6, 2010 | 06:38 PM
  #33
Previc93's Avatar
this is based on time not milage.... there was a dealership in our area that checked the amount of moister and contaminates in brake fluid on every car that went through there shop and they found that no matter the milage that it has a lot of moisture at 3 years. i flush mine every 2.
Old May 14, 2010 | 12:52 PM
  #34
Fieldstone's Avatar
Sure. Yup it would hang up and not go into OD. Would stay at 3,500rpm at 50mph. I got the light show on the dash and later on it shifted kinda rough.
eekmamba
Aug 11, 2016 08:44 AM
fithawk
Jun 7, 2013 12:06 PM
madtodaimax
Sep 4, 2012 11:01 PM
mhrivnak
Sep 9, 2011 03:10 PM
hqly
Jul 5, 2009 09:23 PM
