CEL and error code. Please help
Old Dec 2, 2010 | 05:15 PM
rw02kr43's Avatar
I have an 08 fit and this morning the CEL came on. I went to autozone and had it scanned. It returned a P0128 code. I called the honda dealer and they say at min it will be $175 for a new sensor. Has anyone else here had this code before? What can I do to fix it? Can I just live with it without hurting the car?
Jason
Old Dec 2, 2010 | 05:41 PM
DiamondStarMonsters's Avatar
Jason
Smells like BS to me but it is possible.. P0128 is thermostat related.. But I am sure they would love to ding you for a new sensor while they are in there. Basically it is telling you that the engine is taking to long to get up to temperature, usually because the thermostat has failed in the open position allowing it to circulate through the long circuit and cool off.
Things that could cause a P0128 CEL:
Low engine coolant level
Leaking or stuck open thermostat
Faulty cooling fan (running too much)
Faulty coolant temperature (ECT) sensor
Faulty intake air temperature (IAT) sensor
Here is what to check:
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
OBD-II Check Engine Light Trouble Codes
Old Dec 2, 2010 | 10:57 PM
SilverBullet's Avatar
Real good website, have to bookmark this.
Maw230
Mar 10, 2015 11:15 AM
BansheeScratch
Nov 14, 2011 09:56 PM
markielowski
Jan 2, 2011 03:08 PM
madvibes
Aug 31, 2010 07:16 PM
madvibes
Aug 31, 2010 03:51 PM
