2008 Fit recalls/fog light mod
Old Jul 7, 2011 | 10:23 AM
drock305's Avatar
I never got around to getting the headlight switch or window controls fixed by the dealer and need to schedule my appointment.
I was wondering if anyone with the fog light mod had any issues getting the headlight switch changed out?
Old Jul 7, 2011 | 01:52 PM
Bthasht's Avatar
I would like to no this same question. But i belive the problem they fix is in the headlight harness at light itself. Not sure on that though.
So im subscribed?
Old Jul 7, 2011 | 02:06 PM
MNfit's Avatar
shit that and the window switch recalls are the two I still need to do.
Old Jul 7, 2011 | 03:20 PM
Hootie's Avatar
I'm not sure what exactly the independent fog light mod entails (read it a while ago, don't remember) but the head light recall just involves 1 wire to be removed from the top of the steering column and be replaced a thicker gauge wire.
If I recall correctly the tech will remove the 2 piece steering column cover, remove the wire on top of the steering column which is under recall (which I think is to power the circuit, didn't ask while watching though), solder in the new, thicker wire and reassemble.
Old Jul 7, 2011 | 03:32 PM
Bthasht's Avatar
^^ thats where the independent fogs write to. Probably not a good idea to get that one done.
Old Jul 8, 2011 | 12:21 PM
drock305's Avatar
Yeah the fog mod is in the same harness on the column.. Sooo..
I know there has to be someone with the mod that got warranty work done
Old Jul 8, 2011 | 12:25 PM
MNfit's Avatar
well if that is the same harness as the independent fog mod uses then I would think it would be a very good idea to get that warranty done
Old Jul 16, 2011 | 05:25 PM
soundboy's Avatar
I had the headlight warranty work and the window switch done on my '08 Sport and they did not even mention the Independent Fog light MOD. It stills works great.
Old Jul 26, 2011 | 08:28 PM
drock305's Avatar
sweet thanks!
i forgot all about this thread
Old Jul 27, 2011 | 02:14 PM
polaski's Avatar
Ditto. Actually they tied the wire up a little neater than I had done.
Old Jul 31, 2011 | 06:05 PM
avcm's Avatar
No problem with my dealer in Delray Beach Fl. They noted the mod on the work order, but said nothing about it's effect on the (now expired) warranty. Hope this helps.....
Old Aug 2, 2011 | 08:21 AM
drock305's Avatar
Thanks guys.. I need to make an appointment
Old Aug 2, 2011 | 12:09 PM
drock305's Avatar
Also, how long would you say each of the changes took? There isn't a Honda dealership within 100 miles of where I live so I have to make a day out of it..
Old Sep 8, 2011 | 08:14 PM
whiteGD3's Avatar
I work for Honda done tons of these recalls also have a gd3 wit foglight mod and it doesn't affect doing the recall....
Old Sep 8, 2011 | 11:14 PM
Rob22315's Avatar
I put the honda fog kit onto my base fit a couple of years ago. No issues with getting the window switch mod done.
ross154
Jun 2, 2017 05:41 PM
GinoLicious
Mar 8, 2015 08:26 PM
2007Fit5AT
Jul 27, 2013 05:58 PM
ryan1222
May 19, 2011 01:19 AM
Mugen_Dom
Apr 28, 2008 05:20 PM
