Bbs rs frustration help!
Old Dec 11, 2012 | 01:54 AM
kagstoy's Avatar
Unhappy Bbs rs frustration help!
Guys i was wondrin I got a Honda fit 2007. . . . I want some BBS RS on but I do not know what size and what tire should I buy. . . can 17x8.5 fit what tire? modifications? please help thanks in advance I'm new here
Old Dec 11, 2012 | 02:02 AM
ilretep's Avatar
use the search button and do research on this forum first..
you have to take wheel size, offset and tire size into consideration.. and with that consideration, then you'll know if you need modifications to the fenders or not.
Old Dec 11, 2012 | 02:07 AM
kagstoy's Avatar
I already did the research sir. . . but their set ups are different. . more on fashion thing I was wondering if the 17x8.5 can fit without hitting the fenders
Old Dec 11, 2012 | 02:12 AM
ilretep's Avatar
depends on offset.
Old Dec 11, 2012 | 02:23 AM
kagstoy's Avatar
kind sir do you have any idea on the offset that will fit? =(
Old Dec 11, 2012 | 03:11 AM
Subie's Avatar
Welcome aboard. As mentioned, you need to look around the forum threads for your answer. Here's a good start for tires and wheels:
Tire, Wheel, Brake & Suspension Forum sponsored by The Tire Rack - Unofficial Honda FIT Forums
Take your time. Good luck!
Old Dec 11, 2012 | 04:12 AM
kagstoy's Avatar
thank you very much sir. . . i'm very confused regarding what tire and wheel offset to use so that the rims and tire wont hit the fenders. . thanks
Old Dec 11, 2012 | 07:31 AM
chunkylover8200's Avatar
Im 2008, lowered about 1.5 inches from stock, with 15x7 +40offset, and 195/55/15 tires, my fenders are rolled flat and slightly pulled. the tires rub in the rear on harsh bumps with a lot of weight in the car and at high speeds while the front rubs only during sharp turns at low speeds such as parking lots. I would think that 8.5 would be very wide. youre gonna need to be cambered out and your fenders are gonna need a lot of pulling and of course a rolling to make them fit. the fit is not a car that accepts agressive wheels easily, sorry bro
Old Dec 11, 2012 | 09:17 AM
DiamondStarMonsters's Avatar
OP In the three hours over which you had responded to this thread you could have found the answer by searching this forum.
Could you be more lazy?
Old Dec 11, 2012 | 09:28 AM
Type 100's Avatar
+1,000,000
Google is your friend.
And by the way...8.5" on a GD is just asking for trouble, period.
Old Dec 11, 2012 | 10:48 AM
MNfit's Avatar
put it this way my 15x7 +32 where pretty flush with the fenders and I rubbed on bumps and turns.
brewskis with the broskis
13
May 26, 2015 02:31 PM
honda_82
Nov 7, 2011 09:35 PM
GTornado
Apr 5, 2011 05:55 AM
FELIXY69
Jun 30, 2009 06:51 PM
xmathx
Mar 20, 2009 05:18 PM
