Rear wiper arm removal
Old Oct 11, 2013 | 05:28 PM
Red5's Avatar
Hey guys,
My rear wiper motor burned out on an 07 fit. So I got one from eBay, followed instructions on the DIY to replace and mod it to stand up right. No problems. How does one go about removing the rear wiper arm? The thing is stuck as stuck can get. Soaked it with wd40 to no avail. I'm afraid to damage anything. I've been pulling at it as suggested quite hard. Any tips/tricks?
Old Oct 12, 2013 | 01:34 PM
einstein77's Avatar
Removal
Usually, people forget to remove the nut first. After that, it usually takes a little jiggling and twisting while pulling outward.
Old Oct 12, 2013 | 04:07 PM
Red5's Avatar
Got the nut off, the arm was giving me problems, but I picked up some PB Blaster and it came off like a dream. Mod installed.
Old Apr 14, 2014 | 11:24 PM
roughseas73's Avatar
hi guys... got the same problem here on my '08... can't pull out the wiper arm after removing the lock nut... ir the rear wiper arm just snug fits on the stud or is it threaded? thnks need help here...
Old Apr 14, 2014 | 11:27 PM
Marrk's Avatar
I'd be grateful for any pictures that you post on this.
Old Apr 15, 2014 | 08:49 PM
mahout's Avatar
After removing the nut you justpull or pry thearm off a grooved shaft. It is tight but the trick is pulling the arm straight out and not bend the arm. When you pry use a cloth, pad etc to protect the paint.
And check the position of the arm so you can align it when its reinstalled.
Old Apr 15, 2014 | 08:51 PM
Marrk's Avatar
Where is this locknut you speak of? I never got even that far.
Old Apr 15, 2014 | 11:29 PM
mahout's Avatar
The nut is the pivot of the arm; its under a plastic 'cover' that must be unclipped to access the nut.
Old Apr 18, 2014 | 11:24 PM
So*Cal Fit's Avatar
https://www.fitfreak.net/forums/fit-...wiper-mod.html
pip_rocks
May 14, 2025 01:20 PM
kkim
Jan 9, 2025 02:36 PM
Maxxx
Apr 20, 2016 12:20 AM
codenamezero
Mar 3, 2011 10:00 AM
FrogDaddy
Sep 14, 2006 10:44 PM
