Lowering Problems
Old Jan 7, 2014 | 07:11 PM
Mikelmartin168's Avatar
Lowering Problems
I hope somebody can give me some help on my problem. I bought an eibach prokit spings used and had it shipped to the Philippines. Now when I installed it the rear seems to be lower than the front. Its installed with the logo facing up. I have trimmed the bump stop on all four corners. Is there a reason why its no sitting right?
Thanks in advance guys!
Old Jan 7, 2014 | 08:20 PM
Waiz's Avatar
Avid FitFreak Poster
That's totally normal for the Fit as explained in this thread:
https://www.fitfreak.net/forums/fit-...than-rear.html
Old Jan 7, 2014 | 09:15 PM
Yup I read That while searching for a solution. Its really a drastic difference. I might remove the eibachs and put the stock one back in the rear. I will take a picture when its not raining.
Old Jan 8, 2014 | 07:26 AM
I just installed the oem rears back. It has an agressive stance now. Will run with that until I can afford some coilovers
Old Jan 8, 2014 | 08:48 AM
DWils's Avatar
Mine was the same, but with Progress springs instead. If you measure the height of the frame off of the ground it would be pretty even in the front and back, but again, it all depends on how much the front and rear are lowered. It also depends on if you want the frame parallel to the ground, or equal wheel gap in the front and rear. And pictures of how it sits now?
Old Jan 8, 2014 | 11:13 PM
mahout's Avatar
Sure you got the right springs on the friont and rear. mine didn't have rearward rake. If you did get them right you may need spacers on the shock upprer mount.
Old Jan 8, 2014 | 11:16 PM
mahout's Avatar
Be careful with stock rea springs understeer is increased; harder ton turn corners.
Old Jan 9, 2014 | 07:35 AM
Oh wow really.. Would you suggest I put the eibachs in and go with the spacers instead? @mahout
Old Jan 9, 2014 | 11:26 AM
mahout's Avatar
Either that or add a rear sway bar, which might be preferrable.
Old Jan 10, 2014 | 08:35 AM
Thanks! Will be searching around for a rear sway bar.
cocomartinreyes
Aug 4, 2013 02:59 AM
ModR
25
Sep 3, 2012 11:09 PM
P4IIX
Dec 15, 2011 10:51 AM
Mike413
Florida Community
Mar 25, 2010 10:50 PM
iLUVYOURGE8
Jun 18, 2009 06:09 PM
