Meldew issue
Old Jan 20, 2014 | 05:30 PM
JJuurlink's Avatar
Meldew issue
Hello hello,
I had a water leak from the driverside rear door. I was able to fix the leak with some sealant but now everything is meldewy. The carpet/cusions under the rear seats were soaked. Any idea how I can remove and clean them?
Thanks!
Old Jan 20, 2014 | 10:43 PM
devmail's Avatar
My carpet is drying right now as we speak from the same problem. I recommend taking the carpet right out, you'll have to remove the seats, center console and some trim but there may be some surface rust underneath that needs attention.
Check out the Service Manual for the Honda Fit here: Honda Jazz 1.4 CVT Making Comfortable . The link is on the top right...not all pages are the exact same as our 1.5 but most of the body stuff is.
Old Jan 21, 2014 | 12:02 PM
Spacecoast's Avatar
If its soaked, then best to remove. I've used a good shop wet/dry vac, towles and paper...but really the best is to remove.
aelk799
Apr 4, 2018 11:57 PM
TommyMadison
Jan 31, 2018 09:44 PM
User1
Jan 17, 2018 07:46 AM
Coppatop85
Sep 14, 2012 08:34 PM
RedFitBaron
Oct 19, 2010 07:38 AM
