Parking Light Replacement Issues! Help!
Old Mar 20, 2014 | 10:59 PM
ikutoisahobo's Avatar
Parking Light Replacement Issues! Help! [SOLVED]
Well, I just got to replacing the parking light bulbs through the old painful fender liner way. I thought it was going to be just like the DIY (https://www.fitfreak.net/forums/fit-...ng-lights.html)
However, unlike the bulb connector dongle housing thingy-majig, is much different in my Fit, and it doesn't want to f***in come off!
My parking light 'dongle'
DIY parking light 'dongle'
I tried everything to get it off, twisting it, pulling it, heck, even pushing it.
I hate seeing one of the parking lights not functioning.
Old Mar 21, 2014 | 02:46 PM
Help me out guys
Old Mar 21, 2014 | 03:11 PM
Waiz's Avatar
Avid FitFreak Poster
Only option is to lightly heat up the location or just pull strongly
Old Mar 21, 2014 | 03:14 PM
D429302's Avatar
those can be a bitch. spray sum kind of lubricant on the mating surfaces if u can. im pretty sure its twist so just keep twisting away! it should be counter clockwise.
Old Mar 21, 2014 | 05:48 PM
Okay, now I'm confused, one guy is telling me to pull hard the other one is telling me to twist. I'll do a combination of both and get back to you guys.
Old Mar 21, 2014 | 06:39 PM
D429302's Avatar
none of those bulbs are press fitted into the headlight assembly....he probably ment pull as in turn harder.
Old Mar 21, 2014 | 08:31 PM
Yeah, I got it.
Finally, after 20 more minutes of struggling I finally got it to turn, I used a ton of force with pliers to twist it counterclockwise, then I yanked on it once...nothing happened, yanked on it twice, it move just a it, and the third time it came right out!
I was planning on replacing both sides, because I knew the other one would appear dimmer, but f-that idea, I'm not going through the hassle again.
jimmyparky
Jun 12, 2013 11:16 PM
Black01
Jan 8, 2011 10:56 PM
OverlordOfToast
Apr 25, 2010 05:47 PM
crash001
Feb 22, 2010 08:23 PM
WhiteNoise
Mar 29, 2009 10:26 PM
