'07 manual suddenly very difficult to shift intermittantly
Old May 18, 2016 | 05:04 PM
ezone's Avatar
Sounds like you may need a professional to go drive it and get to experience the problem first hand.
Old May 18, 2016 | 10:57 PM
doctordoom's Avatar
Supervillain
If you haven't already, try pumping the clutch pedal 4-8 times the next time it won't shift. Does it shift after that?
Old May 19, 2016 | 08:49 AM
Jake Fowler's Avatar
I could be way out of wack here so feel free to tear me up in that case. I am almost positive the fits have a Clutch Delay Valve inside the master cylinders. Could it be possible that valve (pretty thin more than likely) Is semi-clogged or intermittently clogged and when it's "tough" to shift you are forcing something into there. Key bumping didn't work but the time it took to take the key out and think about your decisions in life (What I would be doing with the problems you are experiencing) and then restart it, whatever particulate could have settled back into the master?
Again speculation just thought process. Maybe replace CMC?
Old May 20, 2016 | 06:47 PM
Xcrave's Avatar
Originally Posted by dwtaylorpdx
Bad throwout bearing can cause many of the listed symptoms, but once your in there you always do the clutch..
The trans and engine are tied together, the clutch only sees the torque between the crank and input shaft, you can get shuddering if a mount goes bad because tire/axle torque overwinds the powertrain though. Rust is the biggest reason springs break in clutches, there is enough venting in the bell housing to allow water intrusion.. Salted roads make it even worse.
Here was my outcome.
Throwoff bearing was average but nothing out of the ordinary.
The springs really went out with a bang. I was in NJ when it happened. 7 hours from home!
Attached Thumbnails '07 manual suddenly very difficult to shift intermittantly-80-image_b9c93454fa80e3f2fde159f3bbf549cc582ded48.jpeg
Old May 21, 2016 | 01:27 PM
Lance's Avatar
ummm
Do you think this is common of clutches to do this or what causes this kind of failure.?
Old May 22, 2016 | 02:08 PM
ezone's Avatar
Spring failures do happen.
JerryHughes
Mar 25, 2021 08:42 PM
BigRedWeather
Jul 18, 2016 01:43 PM
coolo0220
May 6, 2015 07:46 AM
BrianFantana
Jun 22, 2013 09:51 AM
underdog
20
Aug 9, 2008 09:45 PM
