Transmission fluid
Old Sep 6, 2018 | 01:08 PM
ben_fit's Avatar
Transmission fluid
Hi
Does a Honda Fit (2004) use CVTF or ATF automatic transmission fluid?
Old Sep 6, 2018 | 05:57 PM
sarasube's Avatar
have to say atf .
Old Sep 6, 2018 | 08:33 PM
ezone's Avatar
Originally Posted by ben_fit
Hi
Does your car have a CVT transmission or an automatic transmission? (Honda has different fluids for each in N.A.)
Check the trans dipstick, does it have a tag that tells which fluid it requires?
Old Sep 7, 2018 | 03:42 AM
ben_fit's Avatar
Thank you for your reply.
It's CVT, confirmed with the local agency. On the dipstick, it was written ATF. That's confusing.
Old Sep 7, 2018 | 09:05 AM
Alco RS-1's Avatar
Do you have the owner's manual for your car? That would be worth finding. I'd want to be extremely confident in the decision, as you could ruin your transmission with the wrong fluid. It's worth delaying the fluid change until you are sure of things.
Old Sep 7, 2018 | 09:28 AM
ezone's Avatar
Those older CVT trans originally did use regular ATF, but Honda developed a CVT specific fluid around that time and it is now the official correct fluid.
ATF will probably work as well as it ever did but the CVT fluid will probably be a little better.
Honda now has more than one type of cvt fluid in use, and they are not interchangeable.
In the USA this would be the fluid for your CVT trans (picture):
The fluid called hcf2 is only for much newer cvt trans, not yours.
Old Sep 7, 2018 | 10:06 AM
ben_fit's Avatar
Unfortunately, i don't have the manual.
DArkk
May 11, 2016 10:52 PM
SilverEX15
Sep 27, 2015 03:58 PM
mist303
May 2, 2015 03:26 PM
gmbdelsol
Mar 22, 2010 06:02 AM
savior
Aug 24, 2008 11:24 PM
