Interesting video about Denso starter noise
Old 02-12-2019, 05:55 PM
doctor J's Avatar
As you see the starter makes this noise when it is not engaged in flywheel (over running clutch is ruled out)
The only thing is left unchecked is the planetary gear set and the starter sounds like my old DeWalt cordless drill as it stops.
The rebuild Autozone starter I took apart on the wrecking yard had liberal amount of grease added to the planetary
Ring gear and carrier
while previous starter from overturned car had black goo on the gears
Looks like grease makes a trick (but won't help if bushings are messed up)
Old 02-20-2019, 05:55 PM
0ufit's Avatar
My 07 CRV made that grinding noise for years at a cold start. It did eventually fail, but thankfully you get a pretty good heads up when it is getting close to the end.. My Fit does it as well so it'll only be a matter of time.
doctor J
11-11-2023 11:38 PM
doctor J
01-31-2021 05:31 PM
doctor J
02-20-2020 05:57 PM
Santiad
12-28-2013 01:03 AM
DCTepper
11-22-2013 07:41 AM
Quick Reply: Interesting video about Denso starter noise
