Breather Hose
Old Feb 27, 2012 | 06:46 PM
bdogpot's Avatar
Question Breather Hose
I want to attach speedflow fitting to the hard line engine side and the fitting for intake side. What type of fitting would I use to take the hard line spots and make them - 6 an. I was looking at the speedflow -6an to 3/8 hardline fitting, but the intake inner diamter hole is 3/8 the outer is between 15/32 and 7/16. havent taken measurements of hardline breather hose connection. But it should be similar, or around those numbers. any suggestions on what to do?
Old Nov 27, 2012 | 08:43 AM
bonylad's Avatar
Try it. Not being sarcastic, but pioneers seldom have soemething to work off of. Get a fiting, try it. Then post up a DIY for the community. Win.
Old Nov 27, 2012 | 09:31 AM
bdogpot's Avatar
I actually already did accomplish a way to do it. The tube that comes out that the hose attached to has a hump at the end. Not sure what it is called. Anyways, you have to get - 8 AN push lock hose. To secure the hose use a - 10AN screw crimp. Because the rest of my hose and stuff was - 6AN, a few reducers and extra fittings were used to connect the hoses to the catch can. If you want to see a completed look of every thing put together, and I have another post the is titled prm intake and oil catch can. If something to that nature. Hope this helps out.
wzlfit
Apr 4, 2015 06:26 PM
s0x
Oct 13, 2014 05:41 AM
pokems23
Aug 2, 2014 09:36 PM
ezduzit
Aug 4, 2011 02:47 PM
jezzy's jazz
Feb 20, 2007 05:43 PM
