Check Engine Light After CAI Install
Old Apr 6, 2012 | 08:29 AM
BlackPearlFIT's Avatar
So, I installed a takeda CAI on my ge8. During install I had the battery disconnected and after installation I reconnected. After I drive for awhile the check engine light will come on and then I will reset the battery to make the light go off only to see it come back on in the future. I end up repeating this process about every 7-10 days. Right now I am currently driving with the check engine light on, which I have never done yet? Is there something I should worry about? It seems to drive fine so far...
Old Apr 6, 2012 | 12:25 PM
so is the check engine light being on after an intake is installed normal?
Old Apr 6, 2012 | 12:33 PM
Funkster's Avatar
No, not normal. Make sure all your sensors are reinstalled and the connectors are clean and plugged in correctly.
Old Apr 6, 2012 | 12:37 PM
I had a DIY intake on and it did the same thing. What should I use to clean it? Also I have un-installed and re-installed about 3 times... keeps happening
Old Apr 6, 2012 | 12:43 PM
Funkster's Avatar
I would pick up some CRC Electronic Cleaner and do a quick spray on the MAF sensor to make sure it is clean. I would use a Q-tip to gently and carefully wipe out the connectors.
DO NOT touch the internal wires of the MAF. They will break very easily. Just gently spray them with the electronics cleaner.
Old Apr 6, 2012 | 12:49 PM
Alright thanks, I've had the intake on for maybe 2-3 weeks. I have not run into any problems yet, but I'll clean them this weekend. Thanks for the help.
Old Apr 6, 2012 | 02:32 PM
Funkster's Avatar
No problem, hope it works out for you.
Old Apr 9, 2012 | 09:26 AM
Check engine light has been off for 3 days consistently now
Old Apr 9, 2012 | 10:09 AM
Btrthnezr3's Avatar
Sweet...hope it stays that way!
Old Apr 9, 2012 | 11:24 AM
Funkster's Avatar
Awesome, hope it continues!
yogs
Jun 1, 2025 02:46 PM
Stacie Kahns
Sep 28, 2017 10:46 AM
muffins
Aug 13, 2014 09:48 AM
paulfit
May 14, 2010 02:02 PM
FELIXY69
Oct 13, 2007 11:30 AM
