GE8: Piggy Back &or ECU Reflash
Old Jan 17, 2015 | 08:22 AM
yovtecjustkickedin's Avatar
Added HPS 27-102P Short Ram Air Intake Kit to my Fit and took 1.4 secs off 5-60 MPH which now stands at 9.1 secs.
Looking to add an axle back exhaust, considering:
HKS 32003-BH006 Hi-Power Exhaust
Tanabe T70143A Medalion Touring
Plan on installing:
DEN 5310-IK22 (indexed)
Been told I need to install a "Piggy Back" and/or ECU Reflash to maximize HP. Are these two items the same thing? If not, what is the difference? What are the advantages and disadvantages of each? How do they fit into dyno tuning the car? What are the choices? Which one is best and why? Think it would be nice to be able to adjust Fuel/Air mixture - lean it out during highway driving, set it richer for performance.
Any info./links you can provide is appreciated.
Best,
Yo
Old Jan 17, 2015 | 09:01 AM
De36's Avatar
A Piggy-Back is an adjuster that "piggy-backs" (is wired to) your OEM Engine ECU. Once the piggy-back is installed you bring the car to a tuner. The tuner puts you car on the dyno and tunes the piggy-back based on the exhausts air/fuel ratio.
A Reflash; you send you OEM Engine ECU to a tuner, give him a list of your mods, and he tunes it appropriately based on his experience.
There are different levels for both. A piggy back like the Apexi SAFC only tunes fuel. Where more advance like the AEM FIC tunes fuel and ignition timing. And so on... It really depends on your purse.
Old Jan 21, 2015 | 12:05 AM
07fit916's Avatar
look into this. it is very similar to flashpro. i am running one of the first (if not the first) units on my GE.
https://www.fitfreak.net/forums/fit-...u-reflash.html
Old Jan 21, 2015 | 09:07 AM
De36's Avatar
Where did you order it from? How do you tune? Downloadable map or dyno tune required?
Old Jan 21, 2015 | 11:08 AM
07fit916's Avatar
I ordered it through ktuner since it was a test unit. But if your ecu is one of the ones listed as suported in that thread then you can order from any of the dealers. Dealers | KTuner, LLC
I'm not familiar with the software or with tuning fuel and ignition tables so I opted to go with an etuner (VitViper). He sends you a map to flash to the ecu and then you datalog and send that back. And you repeat until the tune is completed. But you can also dyno tune if you want. Just need to find a tuner familiar with the tuning software.
bryz_
Feb 20, 2012 06:30 AM
manuelgbn
Feb 16, 2011 02:56 PM
buttersandpaper
Feb 15, 2011 11:22 AM
xtreme
Apr 1, 2009 06:59 AM
REXXXXXXXXX
Jan 14, 2008 01:57 AM
