2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
DIY: 09 Honda Accord's Horn Upgrade
Old Aug 29, 2010 | 07:27 PM
  #121
ATLfit10's Avatar
did my accord horn today, big difference! Like shaka I was able to install VERY easily without having to remove both of the little clips that everyone seems to be breaking. I only took the one closest to the horn off using a VERY small flathead (i.e. almost eye glass repair kit sized) and if you look closely when prying at it you can see the inside tab that needs to be pushed down in order for that clip to release.
Old Aug 29, 2010 | 08:06 PM
  #122
MrMondayNite's Avatar
GJ & thanks for the tip as I patiently await my accord horn to come in.
Old Aug 29, 2010 | 09:35 PM
  #123
mxl180's Avatar
Glad I could help
Old Aug 29, 2010 | 10:04 PM
  #124
ATLfit10's Avatar
Originally Posted by mxl180
Glad I could help
Thanks again!
Old Sep 1, 2010 | 07:20 PM
  #125
shaka808's Avatar
Someone asked what the genuine honda part # was for the '10 Accord horn - here it is: 38100-STK-A02
cost me $28 (because I bought it from Honda) - you probably can find it a lot cheaper elsewhere.
This is the LOW horn only
Old Sep 2, 2010 | 08:59 AM
  #126
This is the same part number as the 09 Accord Horn, for all those that want to know it's the same horn.
Old Sep 2, 2010 | 09:17 AM
  #127
Punisher11's Avatar
I was gonna say the accord horn is $18, but then saw you were from hawaii :\
Old Sep 2, 2010 | 04:35 PM
  #128
shaka808's Avatar
Figured - anyone have the "high" horn? are you suppose to hook both of them up? The honda parts guy said they were out of the high. how the heck would you hook up two anyone with only one terminal?
Old Sep 2, 2010 | 04:37 PM
  #129
shaka808's Avatar
$18?? lol.. yes, we pay an extra "sunshine tax"...
Old Sep 2, 2010 | 04:50 PM
  #130
I could be wrong, but I believe the Fit high (alarm) horn is by the right front headlight, you should be able to swap that just like the low one, if you want to have your alarm louder.
Old Sep 2, 2010 | 04:58 PM
  #131
Punisher11's Avatar
I believe the high one is set for the keyless entry. the low one is for the wheel.
I swapped my low one only and i still get the meep meep horn when i lock the doors.
and yes, the high is located by the headlight, the low is in the middle behind teh front bumper cover
Old Sep 2, 2010 | 06:53 PM
  #132
shaka808's Avatar
Light show
is there any way to turn off/disable the stock blinking red LEDS - i believe they are for the stock radio, and the stock alarm.
The reason is because I installed a clifford 1x alarm and it has a BRIGHT blue LED on my steering column. So now at night, I have the blue led, and two RED LEDs flashing. Looks like a lightshow - an out of sync one mind you.
I know it's minor, buts irritating. lol
Old Sep 3, 2010 | 08:18 PM
  #133
I just installed my new Accord horn, I love it. It's much better than the Fit meep meep horn. Another easy upgrade thanks to Fitfreak.
Old Sep 21, 2010 | 05:01 PM
  #134
SenBlue09's Avatar
great upgrade. it should have came with the accord horn to begin with. def. worth the extra $20
Old Oct 6, 2010 | 05:54 PM
  #135
ShotgunSi's Avatar
Just installed the horn myself this past weekend. Was driving myself mad because I thought I broke something. I had the horn unbolted from the car frame and couldn't figure out why it wouldn't make any noise. Apparently the horn must be completely secured to the frame, I guess as a ground. Once I bolted the horn back to the frame fully it worked fine.
Also if anyone needs the part number for the clips for the latch cover assembly it's: 91518-SM4-003
Old Oct 7, 2010 | 05:44 AM
  #136
Black3sr's Avatar
Broke the clips eh.
Old Oct 8, 2010 | 01:01 PM
  #137
ShotgunSi's Avatar
Originally Posted by Black3sr
Broke the clips eh.
I bought two just in case. I ended up breaking one and didn't remove the second one. I just rotated the cover up and around, out of my way.
Old Dec 14, 2010 | 02:09 AM
  #138
jccruises's Avatar
Is the Accord horn the only plug and play option? Is the Ridgeline any louder than the Accord horn? I don't want to do the relay thing and wire to the battery that is needed for the after-market air horns mentioned in other threads. (Stebel, FIAMMs, Wolo, etc)
Thanks,
Old Jan 5, 2011 | 12:50 AM
  #139
cHaNkStA's Avatar
I just bought my horn! Can't wait to honk at some idiotic drivers.
Old Jan 5, 2011 | 01:11 AM
  #140
cHaNkStA's Avatar
