2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
SickSpeed Horn Install Question
Old May 6, 2012 | 02:54 PM
nynhex's Avatar
I have a 2010 AT GE8 and want to replace the wimpy horn with a set of SickSpeed horns (dual tone like Hella). I bought the horns and have my wire and solder gun ready but my question is can I pull directly off of the stock + wire (purple) for power or will I need to include a relay?
Don't want to fry my stock wiring but at the same time doesn't seem like they draw much amperage.
Old May 6, 2012 | 10:05 PM
jnesselroad's Avatar
Usually they say to use a relay. The real Hellas come w it. There are a lot of threads (not necessarily on ff) about the install. Link how these sound! I almost pulled the trigger on a set today, but with only $15 between these and the Hellas I'm still torn.
Old May 6, 2012 | 10:20 PM
nynhex's Avatar
I need to find out how to wire the relay and what kind I need. I have wire and a soldering gun, just need the rest of the stuff. Oh well, another day.
These things are freaking loud. Sound just like Hella supertones to me.
Old May 8, 2012 | 01:44 AM
GoFits's Avatar
Where are you mounting them? I am thinking about these as well. I had PIAA dual tones on my Tundra and really liked them.
Old May 8, 2012 | 08:40 AM
nynhex's Avatar
Stock mounting point in front of the radiator as usual.
Old May 8, 2012 | 10:39 AM
Wanderer.'s Avatar
I've used the PIAA horns which look to be about the same thing and I didn't use a relay, it worked fine. It's probably better if you do, but I don't think it's a requirement. My car didn't burn down.
I just used the stock horn wiring.
Old Jul 23, 2012 | 05:16 PM
klush's Avatar
horn help!?
Where can I buy a relay for my super tones? I have sickspeed horns but I have no relay or wiring. Is it possible to just wire it and everything all stock wiring? If not where can I buy the supplies needed. and what are they?
Old Jul 23, 2012 | 05:48 PM
Wanderer.'s Avatar
Here:
Relay Wiring
The "Switch" is your horn button. You can pick up one of those relays at RadioShack for a couple bucks.
over40pirate
Jul 14, 2013 10:33 AM
SuperMacGuy
Mar 27, 2013 09:14 PM
hybridctr
Sep 20, 2012 11:01 PM
gkitf16
Sep 8, 2011 10:56 PM
CrystalFiveMT
Nov 6, 2008 12:55 AM
