help! cut out door speaker grills
Old Oct 26, 2010 | 02:49 PM
NipponFit's Avatar
Hi everyone,
I wanted to cut out the speaker grills in the car. I've replaced them with aftermarket speakers but the speakers seem to touch the door panel when there's too much bass.
Any suggestions on what to use to cut them out? I plan on replacing the stock grills with the ones I received from my speaker manufacturer.
A friend of mine recommending an air saw but going at $200 so I can just use it once seems a bit too much.
Any suggestions would be appreciated.
Old Oct 27, 2010 | 01:39 AM
Fitting's Avatar
I used a dremel tool when I did that on my last car.
Old Oct 27, 2010 | 10:17 AM
NipponFit's Avatar
Are you talking about this?
I'm not sure but is it possible to get the tool as an attachment for my drill? I'm still new to the tool world.
Old Nov 6, 2010 | 01:11 PM
FIT_maniack's Avatar
Maybe rent a tool that you could use? Or borrow one?
Good luck!
Old Nov 6, 2010 | 03:37 PM
johnkimble's Avatar
that's the right tool -- the dremel.
as for an attachment for your drill, i'm sure there are options. one of the things that makes the dremel so handy though is that you can hold it kinda like a pen, and get the exact angle/cut you want. they're cheap enough, and are handy for all kinds of things. you can get them at target even.
after you get one you'd be surprised at how much you use it for random around the house jobs
Old Nov 6, 2010 | 08:12 PM
jcuecker's Avatar
you can gain ~1/2" by dremeling off the plastic ring and honeycomb structure behind the door grill. Thats what i did.
Old Nov 8, 2010 | 07:54 AM
NipponFit's Avatar
Good luck!
Not in Japan. People here don't really have tools unless you're in the business.
That's $100 easy. i guess no choice for an item i'll use just once.
took the plastic ring off and trimmed the honeycomb thing. still hitting the panel.
Old Nov 8, 2010 | 09:07 AM
Ciggy's Avatar
It's very weird that your speaker is coming out that far just for some bass... are they mounted solid are you sure the sound you are hearing is not front the mount moving in and out when the bass hits?
Did you amp the after market speakers? I have had mine replaced almost since it was brand new in 2007 and Ive never had them hit the door panel.
Old Nov 8, 2010 | 06:23 PM
NipponFit's Avatar
I think it's the spacer I put in. If it was a simple aftermarket speaker, I wouldn't have had a problem. The focals I have take up a bit more room overall.
I have a black and decker cordless drill. Can anyone recommend an attachment that would make this job easier? I've yet to see a hole saw for a drill that cuts out 165mm (or 6.5")
Old Nov 9, 2010 | 02:54 AM
Fitting's Avatar
Some aftermarket speakers have large magnet so they have to use spacers. This will push them out to far and rub against the speaker grilles. Only way to clear is to cut the speaker grille and put in a new one over the opening.
If you can't get a dremel then use your drill and frill a hole. Get a hand saw insert it in the hole and saw the grille out.
Old Nov 10, 2010 | 12:37 AM
I agree with drilling a starting hole and hand sawing it out, that is the next thing I would suggest unless you can google for an attachment for your drill or something... Hand sawing just sounds like the cheapest way and I'm assuming you can find one that will work..?
Old Dec 21, 2010 | 10:01 AM
NipponFit's Avatar
Yeah, the hand saw isn't a big deal. I actually have one. My biggest concern is making it look decent.
I guess it's time to buy some masking tape, make the circle and cut it out. Probably a good idea to sand it after too.
Old Dec 21, 2010 | 10:11 AM
jcuecker's Avatar
I recently replaced the plastic grills in my rear doors with metal ones from Parts Express. Looks pretty good and gains you some extra room:
Old Dec 21, 2010 | 09:49 PM
NipponFit's Avatar
You used a Dremel tool? Got any pictures of how it look of just the hole?
MTLian
May 7, 2018 03:56 PM
payluder
Sep 3, 2014 07:38 PM
FITment
Dec 28, 2010 10:11 AM
mdbrich
Jan 10, 2009 02:52 PM
tstan7777
Aug 17, 2008 12:10 PM
