Stripped wheel lug $839
Time to do brakes/routine maintenance. But that wasn't gonna happen today.
Coupla' months ago I had a simple tire repair done at a local tire shop. Apparently the tire guy didn't pay much attention to how hard he hit the lugs with the air gun. When I attempted to remove one of the RF lugs, it was crossed and would not come off. Tried retightening it, which simply snapped it off.
Without tools to deal with pressing out the hub/bearing, needing to deal with long-gone stupidity, I headed to the dealer and they need to replace the hub/bearing. Stud can't be removed on-car, you have to pull the knuckle and press it all out. $839. I'd rather take that out of that dumbass tire clown's head, but can't remember who did it at the time. Whatever, fix it and move on. I've always torqued them @ 85# by hand, first problem ever, lesson learned the expensive way.
why you went to the dealer for this? you know they will rape you. should have gone back to the tire shop or another local place.
i've screwed up and had my tire come off blaming pep boys for not torquing the wheel properly. they checked the cameras and the tech never even touched my wheels. it was my fault since i never torqued it since it was flatbedded to pep boys. they replaced all studs and i was ready to pay up but they said not to worry about it since i go there often enough.
yep live and learn. they've got me several times before i learned.
Bummer! I do not know how difficult it really is to replace one lug stud; when the same happened to me, I had my uncle's shop replace it for me. If it was anywhere north of $100, I would have been charged.
On the front you got to do the whole hub, cause it's a press-in to the bearing. The hub and bearing are cheap, it's the teardown labor & time. Remove the steering knuckle, press the old parts out, press new bearing and hub in and reinstall. Bad design. But lots of stress on these critical parts, so they have to be secure. Rear are very easy to replace a hub, 10 min with hand tools if you're slow. If you were to do a single stud, have to freeze them for pressing them in. But the hubs are the cheap part, not really necessary
). Super easy to do, just remove the spindle nut and pop it off, make sure you have packed new grease in the bearing and the seal is good, reinstall, done. No pressing involved.
Taking care of the rear lugs I'd just change the whole spindle/bearing, get it from RockAuto (Honda wants almost $300 for this
I bought the wheel bearing press kit from Harbor freight for 60 bucks and the bearing for 40 from Amazon, BeckArnley It’s a little bit of a pain but nothing you can’t do in about two hours. Pull wheel off, spindle nut, slide hammer hub off, lower ball joint, half shaft, ABS sensor, press out bearing press in new, reassemble and bring slide hammer back to AutoZone. The rear takes longer to take the tire off and than change the bearing hub assembly.
wh22366
14
Jul 13, 2024 10:45 AM
kentkanaya
Dec 30, 2014 07:18 PM
