Coil overs
Old Jan 11, 2020 | 05:25 PM
Doginthesheets's Avatar
Coil overs
I知 looking for a good set of coil overs anywhere from 600$-800$ have any good suggestions?? I知 looking to lower my fit and 2 1/2 -3 inches
Old Jan 11, 2020 | 06:29 PM
GolNat's Avatar
For that low you probably need some BC's or K-Sport to not rub if you are running higher offset wheels unless you roll the fenders.
If you want a softer ride Tein Flex but the springs are on the softer side so they rub if you go too low.
My Fit on Tein Flex. Had to roll the front fenders but any lower the liners were rubbing over large bumps/dips because the spring rate was on the softer side.
Stock sport wheels:
Old Jan 12, 2020 | 04:23 PM
sultanofslide's Avatar
I'd go with BC coilovers and order them with custom spring rates if you are going to lower it that much or it will be rub city with the stock 5k/3k springs
jazzivtec
26
Dec 18, 2014 05:01 PM
arellanogiovan
Sep 26, 2012 10:10 PM
mo-FUK
Aug 12, 2012 09:59 PM
GE8_typeR
Jul 18, 2012 03:36 AM
