high beam problems
Old Nov 12, 2021 | 09:38 PM
MikeyFit92's Avatar
high beam problems
ive been trying to diagnose the problem im having with my honda fit its a 13 honda fit and every time i switch on the high beams my head lights cut off. what could be the problem. i pulled a few fuses and they look a little burnt . idk if its justa relay or my high beams need new bulbs. i need to fix this problem cause i can bearly drive at night .its to the point its only my day time driver xD
Old Nov 14, 2021 | 12:43 PM
punx45's Avatar
Burnt fuse is bad. That’s the symptom not the problem though. Figure out what the fuse goes to and work your way back. If a fuse is burnt the circuit is drawing too much current. Find out why.
if you don’t have a multimeter, nows probably a good time to get one 😂
Old Nov 21, 2021 | 02:53 AM
56chevydan's Avatar
Check the fuses in the driver's side under dash fuse box. There's a diagram down there explaining each fuse amperage and circuit As I remember the headlight low beams run on one fuse and the high beams run on a separate fuse.
zaobfit
Nov 22, 2014 09:02 AM
evo911
Oct 1, 2013 03:36 AM
einstein77
Feb 10, 2011 01:55 PM
Gordio
Aug 8, 2010 09:09 PM
atran21
Apr 23, 2008 01:20 PM
