Grinding Noises from Front
Old Mar 17, 2024 | 09:13 AM
  #41
Zardiw's Avatar
Originally Posted by Pyts
Throwing in an extra penny's worth: blown suspension can lead to premature failure of cv shafts. their deal is maintaining rotation at an angle, and blown suspension allows a lot more and more aggressive (un-dampened) fluctuation in that angle.
I just did CV shafts on another vehicle and I even had to replace the intermediate shaft. I'd replaced one of the CV shafts about 3 years back but wasn't greenlit for refreshing the front end. Same shaft 3 years later started making a racket every time the car took a turn.
additionally, the intermediate axel shaft (two-piece affair) was out of round/wobbled in rotation coming out of the trans, causing a trans fluid leak from the related output seal. Pretty big deal!
All that stuff works together When one part can't carry its load, the conjoined ones bear it to their detriment.
I actually had the dealer do the front suspension stuff a few years ago, so I think that part is good. However I do drive on dirt roads a lot so maybe it needs to be redone?
Z
Old Mar 17, 2024 | 09:53 AM
  #42
Drew21's Avatar
Originally Posted by Zardiw
There really wasn't any slop. That was just normal back and forth play in the axle/trans gears I think.
Z
Now you've made me curious. When I get a free hour I'm going to pull my front wheels and check. I don't recall having that movement in my 2010 (A/T) when I changed rotors and pads last summer.
Glad you got it all back together.
Old Mar 17, 2024 | 10:32 AM
  #43
Zardiw's Avatar
Post your results........now I'm curious too as to if that's normal.........
Z
Hondafit11
Aug 31, 2020 06:29 AM
rutterhups
Jan 24, 2018 08:00 AM
kwb
Aug 30, 2017 01:43 PM
plee82
Dec 14, 2015 11:33 AM
p220sigman
Nov 29, 2015 10:56 PM
