Shaky Clutch Fork
Old Sep 28, 2025 | 08:35 PM
mrjlr's Avatar
Shaky Clutch Fork
Hello,
I recently picked up a 2012 Honda Fit base with 65k miles and the manual transmission. I started noticing a faint rapid squeaking sound coming from the engine bay. I narrowed it down to the slave cylinder and clutch fork pivot point so i took it apart and re-greased it with some white lithium grease spray, I also sprayed grease onto the pivot points into the transmission. This fixed the problem for a few minutes, then it came back. Looking at the fork while it's running it looks like the fork is shaking more than what would I consider normal, which is what is causing the rapid squeaking, I've attached a video of it.
I wanted to ask: 1. Is this a normal amount of movement, 2. how can I fix the squeaking, and 3. did I use the incorrect grease?
Edit: I should add that I have no problems with shifting or starting.
File Type: mov
KBTOY100
Dec 21, 2024 09:56 PM
kgmcgrath
Jun 23, 2022 09:15 PM
gqcpa
Sep 23, 2018 06:04 PM
desertsp
Aug 20, 2016 06:06 PM
CrazySte
Jan 4, 2012 03:22 AM
