Sports Pedal DIY Install?
Old Oct 16, 2008 | 09:02 PM
neteng101's Avatar
Question Sports Pedal DIY Install?
Has anyone self installed the OEM sports pedals?
I bought them for College Hills Honda and didn't read the instructions beforehand, apparently securing them involves drilling (easy part) and riveting (a new thing for me).
I managed to get a rivet tool with a quick trip to Home Depot...
Amazon.com: Arrow Fastener RH200 Riveter: Home Improvement
So I think I'm pretty set but I've never used rivet tool before. I bought some spare rivets so I could practice with the rivet tool on something else beforehand.
Old Oct 16, 2008 | 09:24 PM
IfTheFoo's Avatar
I haven't seen them, if it were me I might think about drilling the holes as required and using small bolts and nuts, instead of rivets. Reversible, that way.
Old Oct 16, 2008 | 09:30 PM
neteng101's Avatar
Rivets will be reversible too - just requires drilling thru them.
The way they made this thing to fit - you can't really do a screw and nut job on it... the reverse side of where they place the support plate on the accelerator pedal (on AT anyways) is in a hollow chamber so you don't actually drill thru the whole pedal to the back of it.
If I get enough time I'm giving a try tomorrow after work... wish me luck!
Old Oct 16, 2008 | 09:33 PM
IfTheFoo's Avatar
OK, good luck!
Old Oct 16, 2008 | 11:15 PM
AWDturbo's Avatar
Be sure to take some pics!!
I want the pedal covers (we have an Auto) but I'd really like a set of three, with a dead pedal cover, too. If I dont find such a set, I'll probably eventually just get the Honda set.
But yes, let us know how it goes. Pedal covers can be a real PITA to install.
Old Oct 17, 2008 | 01:13 AM
martymcfly's Avatar
I just did this last week - GE8 MT Honda pedal on GD3 MT. Clutch and Brake Pedal are exact fit. GE8 gas pedal is smaller but it still fits on GD3.
Old Oct 17, 2008 | 03:56 AM
feifei's Avatar
im interested doing that too, any pics?
Old Oct 17, 2008 | 09:42 PM
neteng101's Avatar
Got it done this evening. Started with what I thought are necessary tools... in the end, its hard to mark the spots for drilling, so I used a nail to score the area on the accelerator pedal. No drilling needed for the brake pedal.
Did not take pictures during the install since it was nigh impossible to work in the tight spot. You want to drill a pilot hole and then a BIG hole for the 3 holes on the driver's side, but make sure you mask your drill bit so it only cuts through the top part (the pedal is hollow). They aren't kidding about using 5 mm on the second drill - it makes it a lot easier and its the metal plate that holds the rivets, so the big hole is no issue. It makes positioning easier - still I had to mess around and bend the bottom plate so the holes aligned correctly.
Using the rivet tool is pretty easy, push rivet in (I suggest putting in all 3 rivets on the driver's side, just leave them standing) and use the tool and squeeze. It might take 2-3 squeezes to fully pull the pin out and fasten the rivet but it makes for a really solid hold once done. Results are below...
Old Oct 17, 2008 | 11:00 PM
thecheese98's Avatar
Great job! They look really slick!
Old Oct 18, 2008 | 08:03 AM
AWDturbo's Avatar
Great ! Glad it went smoothly.
This is certainly on my planned mod list!
Old Oct 18, 2008 | 10:08 AM
JDM_DOHC_SiR's Avatar
Nice job!!.
Darkshowdo
Jun 26, 2015 01:28 AM
Fit4Pits
Mar 15, 2015 07:56 PM
Taffeta Fit
May 9, 2009 07:32 AM
runbikerun
Mar 4, 2009 12:42 PM
koolkevin1107
May 2, 2008 09:04 AM
